2002 Audio System Wiring Colors
Base Audio System Speaker Wiring Chart:
Back of HU:
Front Driver Side (Wire 2 (+)): Blue with White Stripe
Front Driver Side (Wire 1 (-)): Blue with Yellow Stripe
Front Passenger Side (Wire 4 (+)): Brown
Front Passenger Side (Wire 3 (-)): Brown with White Stripe
Rear Driver Side (Wire 14 (+)): Light Green
Rear Driver Side (Wire 13 (-)): Black with Yellow Stripe
Rear Passenger Side (Wire 16 (+)): Blue
Rear Passenger Side (Wire 15 (-)): Pink
+12v Always On (Wire 6): Yellow
+12v Ignition On (Wire 10): Purple
Antenna (Wire 5): Green with White Stripe
Combo Meter (Wire 22): Red with Black Stripe
Illumination Dimmer (Wire 7): Red with Yellow Stripe
Illumination On/Off (Wire 8): Red with White Stripe
The ESM does not state whether or not the base system is capable of supporting a CD changer. In the event that it does, refer to the "BOSE Back of HU" section below for the CD changer wire colors on the back of the HU
BOSE Audio System Speaker Wiring Chart:
Back of HU:
Front Driver Side (Wire 2 (+)): White
Front Driver Side (Wire 1 (-)): Black
Front Passenger Side (Wire 4 (+)): Green
Front Passenger Side (Wire 3 (-)): Red
Rear Driver Side (Wire 14 (+)): Brown
Rear Driver Side (Wire 13 (-)): Black with Red Stripe
Rear Passenger Side (Wire 15 (-)): Black with White Stripe
+12v Always On (Wire 10): Purple
+12v Ignition On (Wire 6): Yellow
Amp On/Off (Wire 12): Green with White Stripe
Front Ground (Wire 9): Unknown
Rear Ground (Wire 11): Unknown
CD Left Channel In (Wire 42 (+)): Brown
CD Left Channel In (Wire 41 (-)): Yellow
CD Right Channel In (Wire 44 (+)): Light Green
CD Right Channel In (Wire 43 (-)): Purple
CD Left/Right Ground (Wire 45): Unknown
CD TX Data (Wire 50): Black
CD RX Data (Wire 49): Red
CD REQ Data (Wire 48): White
CD Data Ground (Wire 46): Unknown
Input of Amp:
Front Driver Side (Wire 33 (+)): White
Front Driver Side (Wire 20 (-)): Black
Front Passenger Side (Wire 35 (+)): Green
Front Passenger Side (Wire 22 (-)): Red
Rear Driver Side (Wire 34 (+)): Brown
Rear Driver Side (Wire 21 (-)): Black with Red Stripe
Rear Passenger Side (Wire 36 (+)): Blue
Rear Passenger Side (Wire 23 (-)): Black with White Stripe
+12v Always On (Wire 27): Yellow
Amp On/Off (Wire 25): Green with White Stripe
Amp/Woofer Ground (Wire 40): Black
Output of Amp:
Front Driver Side (Wire 30 (+)): Blue with White Stripe
Front Driver Side (Wire 31 (-)): Blue with Yellow Stripe
Front Passenger Side (Wire 28 (+)): Brown
Front Passenger Side (Wire 29 (-)): Brown with White Stripe
Rear Driver Side (Wire 18 (+)): Light Green
Rear Driver Side (Wire 17 (-)): Black with Yellow Stripe
Rear Passenger Side (Wire 41 (+)): Blue
Rear Passenger Side (Wire 42 (-)): Pink
Subwoofer (Wire 24 (+)): White
Subwoofer (Wire 37 (-)): Black
Input of Subwoofer:
Subwoofer (Wire 44 (+)): White
Subwoofer (Wire 43 (-)): Black
+12v Always On (Wire 48): Red
Amp On/Off (Wire 45): Green with White Stripe
Ground (Wire 47): Black
Input of CD Changer:
Left Channel Out (Wire 6 (+)): Brown
Left Channel Out (Wire 16 (-)): Yellow
Right Channel Out (Wire 5 (+)): Light Green
Right Channel Out (Wire 15 (-)): Purple
TX Data (Wire 11): Red
RX Data (Wire 10): Black
REQ Data (Wire 12): White
+12v Always On (Wire 3): Yellow
+12v Switched On (Wire 1): Purple
Ground (Wire 7): Black
Steering Wheel Control Wiring Layout:
Wire A:
The Mode, Up, and Volume Up all connect to one wire.
The Mode button is a direct connect and does not use a resistor.
The Up button passes through a 150 ohm resistor.
The Volume Up button passes through a 605 ohm resistor.
Wire B:
The Down and Volume Down all connect to one wire (Wire B).
The Down button passes through a 159 ohm resistor.
The Volume Down button passes through a 606 ohm resistor.
Wire C:
The Ground is connected to one wire (Wire C).
The Ground is a direct connect and does not use a resistor.
Wire D:
The Trip button is connected to one wire (Wire D).
The Trip button is a direct connect and does not use a resistor.
The wires connect from the switch to the steering wheel via a 4 pin plug:
Wire A is Pin 1
Wire B is Pin 2
Wire C is Pin 3
Wire D is Pin 4
They then join the cruise control and horn switch just before the spiral cable:
Wire A is Pin 14
Wire B is Pin 15
Wire C is Pin 16
Wire D is Pin 19
Once they go through the spiral cable, they connect to the vehicle's main harness:
Wire A is Pin 34 (Red)
Wire B is Pin 33 (Blue with Yellow Stripe)
Wire C is Pin 32 (Brown with White Stripe)
Wire D is Pin 25 (Green with Red Stripe)
They go through the main harness to the 3rd connector on the back of the radio. They connect via a 16 pin connector:
Wire A is Pin 26 (Red)
Wire B is Pin 27 (Blue with Yellow Stripe)
Wire C is Pin 29 (Brown with White Stripe)
Wire D is Pin 63 (Green with Red Stripe) of the Combination Meter
Note:
1) Pin 22 (Red with Black Stripe) on the back of the Radio also goes to the Combination Meter.
2) These are the wiring color codes directly from the Nissan ESM for the 2002 model Maxima.
My Disclaimer of Liability
The information provided here is "as-is", meaning that I am not responsible for it's inaccuracy. Every means possible has been made to verify its accurateness, however, I am in no way liable for any modification/damage/etc that may occur from misuse and/or inaccuracy regarding this information.
Back of HU:
Back of HU:
Input of Amp:
Output of Amp:
Input of Subwoofer:
Wire A:
Wire B:
Wire C:
Wire D:
Wire A is Pin 1
Wire B is Pin 2
Wire C is Pin 3
Wire D is Pin 4
Wire A is Pin 14
Wire B is Pin 15
Wire C is Pin 16
Wire D is Pin 19
Note:
yat70458
08-03-2015 01:16 PM
