1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
What's wrong
Old Aug 11, 2002 | 01:37 PM
Chino's Avatar
What's wrong
Something isn't right here. I ran twice last night and got 17.114 @ 81.94 on my first run and 17.053 on my second @ 82.21 I have a 96 GLE AT w/HKS intake and rear section muffler. Isn't this a bit high?
Old Sep 1, 2002 | 07:17 PM
Chino's Avatar
Re: What's wrong
Could it be the Denso Spark Plugs I'm using? I heard OEM NGKs might be the only ones to use.
Old Sep 1, 2002 | 08:12 PM
deezo's Avatar
Re: Re: What's wrong
What was the outside temp?
Is your Knock Sensor bad?
How much extra weight do you have in your car?
Was the track on an incline?????
Old Sep 3, 2002 | 08:48 AM
Chino's Avatar
Re: Re: Re: What's wrong
Outside temp was in the low 100s. (its Las Vegas, NV)I'm not sure if my knock sensor is bad. How do I check? Well I just took out my spare, jack, and axle. I had some papers in my glove box and a cd case in the car.
Old Sep 3, 2002 | 09:37 AM
Nismo87SE's Avatar
Re: What's wrong
Can you post 60ft and 1/8 ET/trap also?
Old Sep 3, 2002 | 09:53 AM
Chino's Avatar
I'll give you the 60 and 1/8 later this afternoon. I have my slip at home and I'm at work....
Old Sep 5, 2002 | 07:05 AM
deezo's Avatar
The problem was the outside temperature. I'll never go to a track in hot weather again.
Old Sep 5, 2002 | 07:47 AM
WizzaMax's Avatar
I am having real good performance lately and I am running the Denso 2 step colder (non-iridium)
Old Sep 5, 2002 | 08:22 AM
Chino's Avatar
I'm not sure which plugs I have, I just wen to AutoZone and said "Let me get 6 Denso platnium spark plugs". I remember a black box with lightning on it. Which kind are these?
Old Sep 7, 2002 | 06:56 PM
Chino's Avatar
Re: Re: Re: Re: What's wrong
Okay, here is it....
R/T 2.058
60 2.731
330 7.463
1/8 11.304
MPH 64.51
1000 14.559
1/4 17.319
MPH 81.35
Keep in mind I have an HKS SMF intake, along with the HKS muffler (the fools cut of the flange and welded it onto a non-mandrel bent pipe of their own an called it a cat back). I also hear this whistling sound from my engine (I think is my intake) @ 2K RPM. Damn I wonder what is wrong. I'm suppose to get high 15s with an Auto if I do a splendid run. I didn't really chirp or peal my tires at all. I notice take off was really slow and at the high end of my 3rd gear my car hesitates. Help!
Old Sep 7, 2002 | 07:22 PM
1FSTMAX's Avatar
Re: Re: Re: Re: Re: What's wrong
R/T 2.058
60 2.731
330 7.463
1/8 11.304
MPH 64.51
1000 14.559
1/4 17.319
MPH 81.35
It's your reaction time that's huting your times.
Old Sep 7, 2002 | 07:26 PM
Chino's Avatar
Re: Re: Re: Re: Re: Re: What's wrong
I thought the clock does not start until you leave. In other words I though reaction time did not affect my times. If so I suppose I can subtract my RT from my actual time, and that is what I could run? Hmm...
Old Sep 7, 2002 | 07:28 PM
Jamsan's Avatar
i thought reaction time was just for racing the guy next to you, and it had no outcome on your final time....maybe its diff in NV ?
Old Sep 7, 2002 | 07:30 PM
JAIMECBR900's Avatar
Reaction times only affect you in a "head to head" contest. The E.T. is not affected at all by the R/T. His 60' times are very slow. My first guess would be mechanical problems. Pull the codes and see if you have a KS code. If not, check the status of plugs, fuel filter, intake filter. If not, check the status of your exhaust from front to rear. If not, you have a bear on your hands. What kind of milage are you getting under regular conditions?
Old Sep 7, 2002 | 07:44 PM
Vyrus's Avatar
I agree with Deezo it was the weather. 100 degrees is extremely hot. I know there are some sites than let you plug in your time and weather conditions and it will correct it to a normal-day time. You can see how far off you were. And if you are still 16+, change the knock sensor (seeing you have a '96) and plugs to NGK Plats, and check to see if your fuel filter is clogged.
-Cyrus
Old Sep 7, 2002 | 11:09 PM
RS Motorsports's Avatar
Ya reaction time has nothing to do with your 1/4 time, But those 60 ft are high man, I am at 2.5 60 ft at 5800 ft and you are at a considerably lower elavation than I am, either somethn is wrong with your car or you really need to learn how to launch (maybe combination of both). Did you torque brake?
anyway run the codes from your ecu and see if anything comes up.
Ryan
Old Sep 7, 2002 | 11:14 PM
Chino's Avatar
-Cyrus
Well actually the day it was 100 I ran 17.053. This slip was from yesterday 6 Sep 02 and it was in the low 70s outside! I'm not sure how to "pull" codes from the ECU but I will not ask. Since I will probably get the usual "do a search" answer. I will be happy once I reach the 16s. I've been really close but my goal for now is 16s. I'm thinking it could be my HKS sponge filter. It says to replace it every 3k miles. Its been about 7K now, and I cleaned it about 3k ago. However I think the cleaning didn't do it any good. I didn't notice any diffrence in peformance. Hopefully once I get my Ypipe, ECU, b-pipe, and UDP I"ll be in the 16s.....then again hopefully...
Old Sep 7, 2002 | 11:49 PM
ReichMax97's Avatar
You should be in the LOW 16s or high 15s stock. There is definitely something wrong with your car if you need that many mods to break into the 16's.
Old Sep 8, 2002 | 12:02 AM
KLoWnPR109's Avatar
a 2.7 60' can kill your times
Old Sep 8, 2002 | 12:21 AM
jules's Avatar
Im a 96 GXE auto and i ran a 16.1 in the 1/4 for my best time. My mods so far are intake and exhaust. I hope to break into the 15's with a ypipe. I'm pretty sure the temperature had something to do with your time because when I ran it was like 60 outside temp. There maybe something mechanicaly wrong with your car like knock sensor or maybe a tune up. That's just my guess.
Jules
Old Sep 8, 2002 | 05:53 AM
deezo's Avatar
Your 60' is also the problem.
Old Sep 8, 2002 | 07:01 AM
orgasmicNYC's Avatar
How much do you weigh? Are you launching it right? Are you flooring it? Maybe try a different driver? Do the 60k Tune-Up. Get the codes to make sure your KS is not retarding the timing wrong. Then after you done all that run again.
Old Sep 8, 2002 | 05:15 PM
Chino's Avatar
I weigh about 180, my GLE weighs what all the other GLEs weigh. I brake torque till about 1.5k and then lauch at full throttle. I know for a fact that I do not waste time in my launch since I'm flooring it and my car does not chirp at all! I have no wheel spin what so ever. My car feels horribly slow for the first 60 feet. I'm talking Sentra slow. I also know it hesitates around 3k in 3rd gear. Perhaps I have an exhaust leek? It sucks getting smoked by damn civics with only the basic bolt ons.
Old Sep 8, 2002 | 06:53 PM
Wow man I would feel horrible. Do the 60k tune up and check your computer for any codes. Check for an exhaust leak but I doubt it would drain that much power.
Forge277
Jun 13, 2016 09:26 PM
bigfrank
Oct 1, 2015 12:51 PM
pears
Sep 18, 2015 05:25 AM
220k+ A32
Sep 11, 2015 02:18 AM
