1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
What should I lower my tire pressure too?
Old Sep 17, 2003 | 11:46 AM
DanSE's Avatar
I think I am going to the track tonight, so just wondering what I should lower my tire pressure too in the front? Any other tips for new racers? My car is a 99 SE-L Auto(Cali-spec unfortunatly).
my mods are: VB mod
Frankencar intake
Budget Y Pipe
OBX Cat-back
Hopefully I can run under a 16.2 (what I ran the first time I raced). I have added the intake and Exhaust since then, and got really nice tires.
Thanks for any help,
Dan
Old Sep 17, 2003 | 12:22 PM
CullenJ76's Avatar
what size tire are you running and what's the speed rating? i.e. 215/55 VR 16
Old Sep 17, 2003 | 12:34 PM
luckee2bhere's Avatar
speed rating doesnt matter....
what size tires? what kind of tires? and do you normally spin off the line if you floor it?
Old Sep 17, 2003 | 12:54 PM
CullenJ76's Avatar
well speed rating and tread wear ratings do matter...
if you have zr rated or treadwear rating of around 240 or lower you can EFFECTIVELY lower you tire pressure.
the " do you spin off the line" is a good question bro. did not think of that
Old Sep 17, 2003 | 12:55 PM
DanSE's Avatar
my tires are 225/50/16 I think. Z Rated. Eagle F1's if that makes a difference.
Thanks,
Dan
Old Sep 17, 2003 | 01:39 PM
Thanks,
Dan
MOST IMPORTANTLY: DO YOU SPIN OFF THE LINE when you floor it?
Old Sep 17, 2003 | 01:57 PM
CullenJ76's Avatar
those are great tires. you should go around 24 psi maybe a little more or less depending on the weather. do you have a 5spd or auto?
what rpm are you launching at?
Old Sep 17, 2003 | 01:58 PM
CullenJ76's Avatar
oh vbmod, it's an auto. did not notice that before
Old Sep 17, 2003 | 02:01 PM
CullenJ76's Avatar
what are your 60ft times?
Old Sep 17, 2003 | 08:07 PM
although you have an auto there are still variables to consider....
are you spinning of the line?
what psi have you raced at in the past?
is the track sticky?
do you torque brake at the line?
until you answer some more Qs i cant give you a good answer.
with stock 16s and 55 series all season tires i would take my psi as low as 16-18psi in the front. I am 5spd tho and I was staging to 2500 rpm at the line so your psi will be deferent.
back you jack up the psi as much as your heart desires. I usually run 50+psi in the back.
with 17s and 45 series tires i havent liked to take the psi below 24...i think it begins to hurt you if you take too much out....
Old Sep 17, 2003 | 09:19 PM
DanSE's Avatar
Ok, just got back from the track and VERY dissapointed. I put the pressure around 26-27 in the front and left the back alone. I took everything out of the car except the spare and a small tool box (10 lbs). I ran a 16.1 with a .896 reaction time (yeah I know....) I really think my car has the potential to do better than that, especially with the mods I have. My 60' was a 2.66. I spun a little off the line, but not too much. I reved it up to like 2k and then just floored it on the last yellow. I really wish someone would show me how to launch because thats where I think my problem is. (also the fact that I weigh 300 lbs doesnt help lol).
Thanks,
Dan
Old Sep 17, 2003 | 11:20 PM
2.6 is bad. i dont know what autos normally run but no way 2.6 can be good...you likely spun too much.....you dont want to spin more than a split second or its hurting you.
Old Sep 18, 2003 | 11:45 AM
DanSE's Avatar
Should I rev the engine up at the line, or just floor it from idle? Also should I floor it right away or just ease into it?
Thanks,
Dan
BkGreen97
Apr 2, 2016 05:47 AM
Starrider
Dec 18, 2015 04:43 AM
Violator
Sep 9, 2015 10:14 AM
jfl330
Sep 4, 2015 01:44 PM
