1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
is my times gonna change??
Old Nov 15, 2004 | 10:01 AM
tedo007's Avatar
faster than you think
last time i had kumho 711 (215 55 16 )and i had 2.3 60ft and ran 10.1 and it was hot
i jus got new tires continental (225 55 16) and its cold now so what kind of times i would be getting? is it going to help cause i got wider tires?
this is for 1/8 mile track
Old Nov 15, 2004 | 10:12 AM
I30tMikeD's Avatar
Cold....what is cold? Hot...what is hot? I pulled my best 60' on the worst all season skinny tires you could buy. It's about your driving more than the tires.
Old Nov 15, 2004 | 11:44 AM
NmexMAX's Avatar
dot dot dot ...
Too many variables and Mikes right about how you drive it.
Usually, not always as I satted earlier about variables, cars engines generally run weaker when it's hot, but have better traction and run better when cold but have worse traction.
Hot and cold are far too vague terms.
And also, keep the tire pressure the same for both runs to make an even as possible comparison.
Old Nov 16, 2004 | 09:13 PM
tedo007's Avatar
thanx guyz
Old Nov 17, 2004 | 05:38 AM
TAPOUT's Avatar
You will lose
Also changing tire pressure will make more difference for these two tire choices. The new tires are taller too, you should have gone with 225/50/16 to keep the same tire circumference.
Old Nov 17, 2004 | 10:21 AM
tedo007's Avatar
i wanted my wheel gap to fill up thas why i got 55's
kjlouis
Nov 24, 2018 06:09 AM
MatthewsMaxima
Sep 11, 2015 03:21 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
laparka66
Aug 6, 2015 09:36 AM
RealityCheck
Aug 5, 2015 06:18 AM
