1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Damn, my AE is slow...
Old Apr 15, 2005 | 11:24 PM
S00NR1's Avatar
OU > *
Damn, my AE is slow...OKC Thunder Valley Night
..took it out to Thunder Valley tonight after replacing the plugs with new NGK coppers. Ran ten times all at an average of 16.114. I only had one sub 16 run which was a 15.978. This all came with average 60 foots of 2.443. I cant for the life of me figure out why my car was so slow as it progressed down the track because a 2.443 60' aint all that good.
Best Run of the night:
R/T .018
60' 2.400
330 6.763
1/8 10.340
MPH 69.45
1000 13.382
1/4 15.978
MPH 86.85
Old Apr 15, 2005 | 11:29 PM
JClaw's Avatar
Yes a 2.43 is pretty bad. Cutting .15 off of that would bring you down about 3 tenths. But even then you'd be slow. You should run 15.3-15.0. Check your knock sensor. You put 91-94 octane in?
Nice car BTW. 5th gens are pimp.
Old Apr 15, 2005 | 11:34 PM
S00NR1's Avatar
OU > *
Ya, I ran with 93 octane and am unfortunately weighing in at 3350 pounds.....but still, the last time I was at the track I ran a 15.4 without any problems.....only thing different today was about 100 pounds heavier and copper plugs instead of the stock plats.
Old Apr 15, 2005 | 11:36 PM
JClaw's Avatar
If that's 3350 WITH you, it's normal. So no problem here. Pull your codes. It's either the weather or your knock sensor, every maxima owner's best friend.
Old Apr 15, 2005 | 11:38 PM
S00NR1's Avatar
OU > *
No, that 3350 was with me OUT of the car -- it was 3540 with me in it.
Old Apr 15, 2005 | 11:39 PM
JClaw's Avatar
2000-2001 normally have a 3200-3220 lbs curb weight, so something's wrong there. If your tank was full it could have affected that. 80lbs= about .1.
Old Apr 15, 2005 | 11:42 PM
S00NR1's Avatar
OU > *
Nah, the tank was just below 1/4 remaining. Van and Blake went with me and they both weighed in at ~3100 lbs (Blake has an 00 SE man with 16" rims, Van has an 02 GXE auto with 17" SSRs)
Old Apr 16, 2005 | 12:08 AM
whazzzzuup's Avatar
My car weighed 3170 without me in it, with a 1/4 tank of gas and my 2 30lb amplifiers.
My best time was:
R/T .286
60' 2.284
330 6.234
1/8 9.463
MPH 76.45
1000 12.263
1/4 14.639
MPH 94.09
Old Apr 16, 2005 | 11:51 AM
xlcrew's Avatar
I’m Back
i weighed in at 3180 with 1/2 tank of gas my best run was
60' 2.341
330' 6.509
1/8 9.867
mph 73.15
1000' 12.761
1/4 15.187
mph 93.31
i got six runs in i was very consistent, never slower than a 15.3, with an average of a 15.2 at a high 92 mph. 60 foots were 2.3's with two 2.4's(tried different launches that didn't work) but after my last run my car broke, but oh well
Old Apr 16, 2005 | 12:30 PM
Loe max's Avatar
How is your VI? 86mph is awefully low for an automatic Maxima running high 15's.
Old Apr 16, 2005 | 05:52 PM
Brushedpewter's Avatar
<--------Try running 87mph at 16.1
Old Apr 16, 2005 | 06:09 PM
Epacy's Avatar
Unsuccesful STL Coordinator
Nice run Van.
Old Apr 16, 2005 | 07:35 PM
S00NR1's Avatar
OU > *
I dont really know how my VIAS is doing....but everything seems OK. Guess it is about that time to check it though.
Old Apr 16, 2005 | 07:58 PM
I30tMikeD's Avatar
Thunder Valley is a slow, crappy track. But you should still be running faster than that for sure. The terrible 60 foot did not help either. You should be able to pull at least a 2.25 on street tires
Old Apr 17, 2005 | 08:19 AM
S00NR1's Avatar
OU > *
Ya, the thing is I seemed to be launching decently Friday night but still had 10 nearly identical 60's around 2.44. I think my car just might have hit a brick wall the last two weeks since the last time I was out there running a 15.424 with a 2.3 60'.
Old Apr 17, 2005 | 12:32 PM
Epacy's Avatar
Maybe you need to take that OU sticker off. It is slowing you down.
Old Apr 17, 2005 | 01:13 PM
maximaintheface's Avatar
lol why does ur cardomain say 15.1s at 99.3?
Old Apr 17, 2005 | 01:41 PM
deezo's Avatar
R/T .018
60' 2.400
330 6.763
1/8 10.340
MPH 69.45
1000 13.382
1/4 15.978
MPH 86.85
AE's are slow. I know another member that couldn't break 15.7 all day. He had a lot of 15.9's.
Old Apr 17, 2005 | 02:25 PM
S00NR1's Avatar
OU > *
LOL, who knows?? It also says 250 hp and I have no idea where those numbers came from.
Old Apr 17, 2005 | 06:55 PM
Ferbs02SMMax's Avatar
My best time was:
R/T .286
60' 2.284
330 6.234
1/8 9.463
MPH 76.45
1000 12.263
1/4 14.639
MPH 94.09
Quick 5.5th gen you have there.
I'd like to know why our cars can't hook worth a $hit...
Old Apr 17, 2005 | 09:25 PM
Poowill's Avatar
Why would AE be any different? Besides the different stock "exaust", which supposedly give you +7 hp. Is the ECU tuned a bit different. It seems to me too though that it seems a little slower than it should be. I haven't ran any 1/4's but it just should be quicky. It is an auto also. The shift points @ wot are really wimpy as well. Along with the stupid governer that will shift from 3rd to 4th @ 3500 rpm's no matter what you do. I still like the car but why would the AE's be so slow?
Old Apr 17, 2005 | 09:48 PM
S00NR1's Avatar
OU > *
Well...first, the AE's kit adds on probly anywhere between 50-100 pounds and then the AE rims weigh as much as some 18's. The exhaust difference is 5 CRANK hp, not WHP, so you wouldn't even be able to notice a difference. After doing some research on other 1/4 mile AE times, I would say I was right about average.
Old Apr 17, 2005 | 10:05 PM
whazzzzuup's Avatar
Thank you. I was messing with the tire pressure but the track was closing and I couldn't get the pressure right. The fastest 60' time that I had was when I ran a 14.8xx. I'll figure it out next time, after my timing advance.
Old Apr 18, 2005 | 07:15 AM
Let us know how the timing advance feels, and if it makes a big difference at the track.
I'm thinking of a b-pipe/timing advance. See how close it gets me to 97mph traps...
p.s. sorry for the thread hijack.
Old Apr 18, 2005 | 08:27 AM
anthunny's Avatar
my friend has stock 00 GLE and thinks he can beat my 3.5 altima by at least 3cars....
he ran consistent 16.2s all day
Old Apr 18, 2005 | 03:50 PM
Epacy's Avatar
I got the timing advance and I am heading to the track tomorrow to see how it works out. I can feel a little difference. Hopefully that translates to the track time.
Old Apr 18, 2005 | 07:17 PM
good luck. hopefully the weather obliges not too warm...
Old Apr 19, 2005 | 09:38 AM
Epacy's Avatar
Yeah it will probably be in the mid 70's. Hopefully drops more as the night goes on.
Old May 5, 2005 | 09:49 PM
tedo007's Avatar
faster than you think
whoa dude it really is slow. you need to work on your launches and your 1/8 mile is like way bad 10.3.
Old May 20, 2005 | 11:34 PM
S00NR1's Avatar
OU > *
Several of the OKC Org'ers got together tonight to race at Thunder Valley. Three performance mods were completed since the last time I went to the track and I had hoped to post better times since the last, but unfortunately, my 1/4 miles were actually worse. With the addition of the Budget ypipe (sucks ***), the DR mod (worked pretty well), and the timing advance (17*), I had expected to see improved times, but that was not the case. Tonight's best:
R/T .306
60' 2.483
330 6.854
1/8 10.393
MPH 69.83
1000 13.404
1/4 15.965
MPH 87.85
However, there is a little something that I can add that most likely had a significant impact on my times. Tonight's weather conditions were as follows:
Temp -- 95 (arrival at 730) - 85 (departure at 11)
Dewpt -- 65 (arrival) - 70 (departure)
Humidity -- HIGH
Wind -- 0
Considering last time we were at the track the temp was around 55 with little to no humidity, I am thinking that may have made the difference here. Also, Thunder Valley is a notoriously horrible track, so I am hoping that this was the cause of the poor times. I will say this, after averaging out the mph's in the 1/4 from last month's and this month's, the numbers this month were consistently 1-2mph faster...don't really know why though.
Here are some clips from tonight:
Blake making a run in his 2000 5spd SE
http://24.217.142.150/OKC/Blake_1.MPG
Here are two runs I completed, the first without the DR, and the second with the DR.
http://24.217.142.150/OKC/Lance_withoutDR_052005.MPG
http://24.217.142.150/OKC/Lance_withDR_052005.MPG
Here are the times I recorded for these two runs respectively:
Without DR:
R/T 0.141
60 2.485
330 6.936
1/8 10.550
MPH 68.71
1000 13.619
1/4 16.234
MPH 86.21
With DR:
R/T 0.233
60 2.498
330 6.916
1/8 10.464
MPH 69.64
1000 13.478
1/4 16.027
MPH 88.17
Old May 20, 2005 | 11:46 PM
sooner02r1's Avatar
Humidity and heat were definately the two factors that held everybody back. I was trapping 3mph less than usual, even with a .3 better 60', so it all can't be blamed on the car or the driver. Also I will say that whoever talks crap about the quality of Maximas should know that I made 13 passes tonight in near 100 degree weather and drove it home just like it had never been there. OH and also two of the runs were beating a buddy of mine in an LT-1 Formula. I can't brag on the car enough.
Old May 21, 2005 | 05:41 AM
whazzzzuup's Avatar
It was definitely too hot last night.
Old May 21, 2005 | 06:35 AM
I30tMikeD's Avatar
Pulling that bad of 60 foot times makes any comparison hard. Your traps are so low I would really take a look to see if something is wrong with your car...look into the VI not working.
Old May 21, 2005 | 07:22 AM
S00NR1's Avatar
OU > *
Well, first of all, I am running on the stock Potenzas that have about 30% tread left which definitely can't help my 60's. Second, I currently am pulling two O2 sensor codes and the Budget ypipe is still leaking, so those two things combined can't be helping me and I know for a fact I am running rich.
Old May 21, 2005 | 07:44 AM
Epacy's Avatar
13 passes is alot. Gotta love the reliability though!!
Old May 21, 2005 | 08:00 AM
S00NR1's Avatar
OU > *
Ya, I shut mine down after 9 passes that were spread out over about 3 hours. Here is a bit more info just so you know what I was running:
Front tires -- 27psi (hot)
Rear tires -- 35 psi (hot)
Manually shifted the A/t on 7 out of 9 runs (numbers indicated it was faster, but bounced the rev limiter one or two times trying to get used to it)
I keep an Excel spreadsheet with all my times and you can check out the run-to-run differences here, they are listed in order from the first run of the night in the serious heat (730p), to the last run at about 1030pm.
http://24.217.142.150/OKC/Thunder%20Valley%20Slips.xls
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
Vitaly O.
30
Oct 29, 2000 12:23 PM
impossible2stop
Oct 28, 2000 11:31 AM
maximaisokay
Oct 22, 2000 11:25 AM
