1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
First time on a strip since July 5, and I got one pass....
Old Aug 31, 2006 | 06:07 AM
grey99max's Avatar
LandShark has Cosworth
Last night was the first time I've been on a drag strip since July 5th, because of extreme heat and some serious rain lately. I went to KCIR last night and got my first pass at 6:41 PM - got some decent times, but when I went back and parked at my trailer, the car wouldn't start. I have no fuel pressure, apparently.
I used my Harbor Freight electric winch and Sam's club battery pack (nothing but the best) and managed to pull the car back on the trailer, I wound up helping a couple of other guys with problems, so the rest of the evening wasn't a total waste. Saw a Hudson Jet racer with a 359ci Hudson engine and 4-barrel carb plus headers. It sounded mean. I have pictures- it had a in-line 6 flathead with custom head! The owner/driver said he had several Hudsons, like in the movie "Cars". Got home and parked around 11PM.
Times off the slip:
R/T......099
60'.......1.951
330......5.526
1/8.......8.547
MPH......80.48
1000.....11.175
1/4.......13.411
MPH.....101.20
Interesting to me - I hadn't launched in 8 weeks (!) and the old reflexes are still there. The plan was to make one baseline run with the standard automatic (see above) then test the toggle-switch version of the Shift_Fast tranny controller, then try my MSD-controlled version to see if I can raise the shift RPMS and get better ETs. Things didn't work out, though... Next time.
Old Aug 31, 2006 | 07:15 AM
cardana24's Avatar
Blown
good run. How much does your car weigh? you are running the same e/t's that I did with a very similar 60' but my traps were 5-6mph faster.
Old Aug 31, 2006 | 07:49 AM
grey99max's Avatar
About 3300 at the line - with spare tire and jack...
My ETs and such have been pretty good, but the top end just isn't there..
Old Aug 31, 2006 | 07:57 AM
cardana24's Avatar
Blown
what gives then? how much power are you making? Maybe I just need to start spraying down low to get into boost quicker.
Old Aug 31, 2006 | 08:09 AM
grey99max's Avatar
I don't know - maybe I should dyno some day ??? I've been working on getting the VLSD automatic to launch quick and hard and shift quick and hard. Judging from the slips this year (and comments from the losers) the plan must be working. Short slicks, wide rims, DR-mod, VLSD, Jbars, 2-stage NX, a real cold-air INGEN, it all adds up, I guess. And good R/T helps, too.
If I ever tuned the car, the top end might get better....
Any suggestions? I haven't explored much for the top end, really.
Old Aug 31, 2006 | 08:50 AM
cardana24's Avatar
Blown
how big of shots are you spraying on your dual stage? Also your R/T does not affect your e/t or mph.
Old Aug 31, 2006 | 09:01 AM
Tatanko's Avatar
Bacon Lover
VI
10chars
Old Aug 31, 2006 | 09:55 AM
grey99max's Avatar
At the moment, 1st stage is 50-shot and 2nd stage is 75-shot. I can go to 150 + 150 but that wouldn't be pretty....
I know about the R/T things - and that a good R/T will still win races.....
Old Aug 31, 2006 | 09:57 AM
cardana24's Avatar
Blown
sure in bracket racing it will, but when we are just talking about your slip it has no affect
Old Aug 31, 2006 | 10:01 AM
grey99max's Avatar
Originally Posted by Tatanko
VI
10chars
Funny. If I had believed that, I would have done it last year....... Now show me a real 1/10 second advantage over the MEVI, and maybe it's worth the hassle..
Installing hotshot headers with a cutout instead of the stock manifolds, that could be a serious improvement.
Old Aug 31, 2006 | 10:09 AM
grey99max's Avatar
Agreed - but the 60's I've done and the 1/8 mile numbers are good - are yours comparable? Just curious, since you're running a supercharger and , I assume a 5-spd, how the times compare?
Your hp comes on differently than mine - spray is either ON or OFF, so I needed traction to use it. I've never run a FI Maxima, or against any other Maxima - this is Ford/Chevy/Mopar country, with a sprinkling of turboed Hondas.
Old Aug 31, 2006 | 10:42 AM
cardana24's Avatar
Blown
yeah I am curious too. I have only made about 6 total passes in my supercharged car...I'll see if I can find some slips tonight. If I remember correctly I don't think my 8th e/t's are as quick as yours.
Old Aug 31, 2006 | 11:39 AM
Tatanko's Avatar
Bacon Lover
Sorry, wasn't aware you already had a MEVI.
Old Aug 31, 2006 | 12:12 PM
grey99max's Avatar
I'd like to see them, since FI power comes on differently than spray power.
Now if you have big sticky short slicks on wide alloy wheels and spray a 50-shot or 75-shot until your blower pressure reaches a preset number and turns off the N2O, then you could launch as hard or harder than me and pull that stronger top end. Whew.
Darn, would that really work ? Hummm
Old Aug 31, 2006 | 12:17 PM
grey99max's Avatar
I didn't mean to sound so nasty - it read worse than I intended - not like a joke....
The MEVI does pull hard at the top, which is why I built the MSD-controlled Shift_Fast module for my automatic. I need to extend the 1-2 and 2-3 shift points somewhat. I was testing it last nite, but lost the fuel pump after the first pass.
Old Aug 31, 2006 | 01:50 PM
streetzlegend's Avatar
Good run, too bad you couldnt get more. the 1st is most of the time the slowest run, you probably could have gotten very low 13. Did you find out exacly what happend with the fuel?
Old Aug 31, 2006 | 02:25 PM
grey99max's Avatar
Nope - all that happened was a surge of fuel pressure when the key was turned - the prime pulse - which dropped back quickly. It dawned on me later that that shouldn't happen - the fuel pressure will stay up for a long time after running, so something is wrong with that.
I really wanted some Shift_Fast times - the night was cool, the car felt strong, and I was ready to kick Mustang tail - I got one yellow GT on the first run, then died.
Old Sep 1, 2006 | 08:52 AM
Dave B's Avatar
Not DAVEB the parts guy
I need to get back to KCIR now that the 95-102 degree weather we had for about 1.5 months finally blew east. The track sounds like it's still producing decent times.
Old Sep 1, 2006 | 09:31 AM
DandyMax's Avatar
3.5 in the works
The weather's turning cool up here now also so I'm itching to get back to the track too. Supposed to rain this weekend though and I'm having fuel issues and need to tune again so it won't happen till next weekend at least.
Old Sep 2, 2006 | 07:14 AM
Nealoc187's Avatar
SLOW
I don't know what the conditions were like at KCIR last night, but around here it was a GREAT night to get to the track. DA was the lowest I've seen on a race night since I went to the track back in march. It was like 64 degrees at 7pm and baro or 30.20... makes for an 1100 foot DA at my 800 ft elevation track. Lowest I've been to the track to this summer is 1800 feet. But alas I was working on my car instead of racing it.
Old Sep 2, 2006 | 07:26 AM
pbn85's Avatar
13.4 is very impressive for an auto...props
Old Sep 2, 2006 | 08:59 PM
Dave B's Avatar
The DA for KCIR was around 2,000' on 8/30. The track is at 850', temps in the lower 70s, 60-70% humidity, and 30.0 baro. We recently had a shift in the weather over the past days. It was consistently in the mid to upper 90s for about a month. Then late last week a huge cold front blew through.
I'd imagine in the near sea level DA of Fall, he could be running in the 13.1@103mph range.
Old Sep 7, 2006 | 04:35 PM
bigirish's Avatar
Nice time, grey! Congrats.
Old Sep 7, 2006 | 05:48 PM
grey99max's Avatar
Thanks, newbie - er, sir.... Welcome to the *.org. My PB is a 13.31, and if my ECU hadn't decided to cr*p out, maybe I could have matched it.
Your Alty looks pretty impressive. Do you track it a lot? Good times.
Old Sep 7, 2006 | 08:17 PM
bigirish's Avatar
Thanks bro!
Yeah, I have been a member on .net for a couple years, and want to get know you max peeps over here.
13.31 is impressive man! I don't hit the track as much as I used to. I am hoping to get my times down. My PB is the 13.7, and that was w/ my stock tires and no tune. As soon as I get my hs headers put on, I am going to hit the track again. We'll see what happens......
Ryan
Old Sep 7, 2006 | 10:00 PM
DandyMax's Avatar
3.5 in the works
Nice Alti...
Gotta love not having to have a front license plate. It's mandatory here but it kills the front end look if you ask me.
Old Sep 8, 2006 | 08:24 AM
grey99max's Avatar
Thanks bro!
Ryan
I'm putting HotShots on my list, too...
You are going to put on DRs or slicks for the track, right? Otherwise the EPA will ban you because of all the smoke you will be spreading around !! Do a video if possible - you 3.5L guys are fun to watch....
Old Sep 8, 2006 | 10:54 AM
bigirish's Avatar
LOL! Yeah, that is a definite need. I am trying to get slicks next. I have been feathering the throttle off the line, and then slowly getting into the gas at the track in an effort to have some traction. I would love to be able to romp it off the line, like in Jime's vids! Need some slicks asap.
Will have a my vid cam w/ me at the next track outing.
This is just an expensive hobby! But, well worth every dollar!
Old Sep 8, 2006 | 01:02 PM
grey99max's Avatar
Slicks like these ?? (it's the Harley flont plate that does the magic)
Harry's hillbilly racing team - me and the oldest grandson...
http://i48.photobucket.com/albums/f2...heTeam2006.jpg
Old Sep 8, 2006 | 02:53 PM
bigirish's Avatar
Hell yes, those slicks look like they can "git R done". LOL! How much would a pair like that run a fella?
Like the Harley plate too!
Old Sep 8, 2006 | 06:13 PM
grey99max's Avatar
Those are M&H 23/8.5.15 slicks ( $320/pr) on American Racing Outlaw II 15x8 Ford wheels (maybe $150/pr ??). I don't know that 15 inch wheels fit on your Alty, but look in Jeg's or Summitt catalogs for a great selection on tires, DRs, slicks and wheels.
I've had 225/50/15 and 255/50/16 BFG DRs, and these M&Hs have much better traction on the launch. I've scored several 1.9 sec. 60' on the M&Hs - see the slip below ..
Old Sep 8, 2006 | 06:51 PM
bigirish's Avatar
1.9 60' is awesome. I want to achieve that badly!
I am pretty sure that the 15's would not be an issue on the Alty. I need to check to see what I can get for this thing. I will check out jegs. These will have to come next after getting my headers put on!
mvm062
Nov 30, 2020 09:00 AM
kjlouis
Oct 3, 2015 05:29 AM
intimidator
Sep 5, 2015 07:23 PM
trungg86
Sep 4, 2015 04:58 AM
