1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
KCIR Again Last Night - Testing A Couple Of Things - N2O Probs and Shift_Fast Mod..
Old Sep 28, 2006 | 08:10 AM
grey99max's Avatar
LandShark has Cosworth
Trailered back to KCIR again, to try my MSD-controlled Shift_Fast auto tranny controller, and to see what happened to my second nitrous stage.
N20 problem: Last week, I switched both NX stages to 75-shot. On the first launch, the engine began cutting out as soon as I hit 2nd stage (in first gear). Letting up and getting back into it in a second or so, everything was OK. Whew. This happened twice, so I put 50-shot jets into 2nd stage - same problem for last two runs.
Last night I had the same problem - the engine would cut out if I got into the second stage too early. On my 4th and final pass, I waited until I was into 2nd gear before spraying 2nd stage, and everything ran OK. I suspect I don't have enough spark voltage, although I have new 2-step-colder plugs installed, gapped at .031. Something is definitely wrong.
I was going to try the manual version of the Shift_Fast tranny controller (thanks, Jime) but I couldn't get a feel for manual shifting during extensive on-ramp tests this week, so I decided to give my MSD-controlled Shift_Fast a chance. It works great - I set the shift point, and it shifts the tranny hard and fast, right at the set point.
Sep. 27 2006 KCIR Drag Strip
Nitrous: 75-shot 1st stage, 50-shot second stage
On run 1-3, I had to lift off 2nd stage after first engaged ?
On run #4, I was very slow to engage, but no cutting out. ?
First Test Of MSD-controlled Shift_Fast Jime Mod... !!
Shift:....stock.......6100.......6300......6300
R/T..... .117...... .160........ .095....... .368
60'.......1.986......2.033.......1.994.......2.059
330......5.566......5.628.......5.548.......5.690
1/8.......8.599......8.646......8.565.......8.727
MPH.....81.13.......81.37......81.63.......79.94
1000....11.229.....11.274.....11.199.....11.383
1/4......13.463.....13.508.....13.432.....13.628
MPH.....100.72.....100.63.....100.68.....101.41
On last pass, car pulled like a b*ch once second stage was engaged. There's hope. I'm still looking for a full 75-shot + 75-shot pass.
LtLeary
Sep 14, 2015 12:33 PM
Maxima30
Sep 7, 2015 06:13 PM
minsbang
Sep 5, 2015 05:36 AM
jfl330
Sep 4, 2015 01:44 PM
crazyespn
Sep 3, 2015 01:30 PM
