1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
'05 5at 14.796 @ 94.39
Old Dec 2, 2006 | 10:26 PM
RHMax's Avatar
Newbie just Registered
R/T - .746
60' - 2.282
330 - 6.253
1/8 - 9.549
MPH - 72.56
1000 - .000(n/a)
1/4 - 14.796
MPH - 94.39
Sunny 75 degrees, head wind constant 30+ mph.
How much quicker if I didn't have to fight the wind?
K&N panel, TS ECU, y-pipe, stock mufflers, new piping w/ Magnaflow resonator, stock wheels and tires.
Old Dec 3, 2006 | 01:59 AM
Ceasars Chariot's Avatar
Old Maxima Legend
not sure on headwind and how much it takes away, still a nice run...maybe 14.5-.14.6 in good conditions ? add your timeslip to the timeslips database and work your way up the ladder !
Old Dec 3, 2006 | 06:51 AM
t6378tp's Avatar
Turbo 3.5
That is really good time and very good mph, I ran a 14.3 but my mph was only 91
next year I am looking to be in the 13sec club
Old Dec 3, 2006 | 09:19 AM
LA02MAX's Avatar
that's a very good time, and an even better 60' you could probably see a 14.5 or 14.6 in favorable conditions.
Old Dec 4, 2006 | 12:29 AM
RHMax's Avatar
Thanks. Next time I'll lose some weight and get better tires, and maybe 3/10 off or better...
Old Dec 4, 2006 | 02:03 PM
Glude's Avatar
Good times, pull all the stuff outa your trunk next time and go with minimal gas. I also usually raise rear tire pressure and mess with the front to see if it helps your 60fts. A lil off topic but can the drop resistor mod be done on the 05 autos? If so u might consider it.
Old Dec 4, 2006 | 03:37 PM
RHMax's Avatar
Front tire pressure was 32psi and poor traction on the track, the tires squealed thru 1st gear with pretty light throttle. I was thinking about losing some stuff, but kinda wanted to know how it runs full trim. Now I do.
Old Dec 4, 2006 | 08:05 PM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showpost.ph...7&postcount=17
MIKERNM1990
Dyno Discussion and Slips
50
Jan 29, 2017 04:28 PM
jtrem83
Mar 25, 2014 09:46 AM
MIKERNM1990
397
Apr 29, 2013 10:48 AM
RHMax
35
Dec 10, 2006 12:03 PM
