1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
WTF still no 13's
Old Apr 20, 2007 | 09:51 PM
t6378tp's Avatar
Turbo 3.5
WTF still no 13's
So I went to the track tonight to test out my new mods: 2.5" exhaust, regapped plugs, mazda wheels, walbro fuel pump and afpr
everything was going well I spun alittle but no biggy till my afpr took a crap during the run, I still ran a 14.0 but WTF. I was checking my vac line cause the car was idling crazy and would not hold a steady rpm when I pulled the vac line from the afpr gas starting coming out so I rigged it up to get home and I will return the afpr in the morining
here's how I ran spinning off the line and with a bad afpr, one good thing my mph went up almost 3mph from my last run
60ft: 2.1
330: 5.8
1/8: 8.9
mph: 77.5
1000: 11.7
1/4: 14.0
mph: 95.98
Old Apr 21, 2007 | 07:47 AM
SonicDust187's Avatar
Your mph is alittle low, I was hitting 14.4 at 95mph with 50 shot and 2.2 60'. Only mods was intake and ypipe with 2 step colder plugs.
Old Apr 21, 2007 | 08:07 AM
LA02MAX's Avatar
did you read his post?
Old Apr 21, 2007 | 08:19 AM
babymac's Avatar
BOOST 4 LIFE!
Don't worry tom you'll get there. I agree though I still don't understand why your mph is so low?? Even when you did the 14.3 your were trapping at 93.At 14.0 you should be trapping at least 98mph. I really think you need a tune.
Old Apr 21, 2007 | 09:28 AM
t6378tp's Avatar
Turbo 3.5
then I am only 2mph off and like I said my afpr went ape sh@t during the run so maybe I would have trapped higher
also I return the afpr this morning
Old Apr 21, 2007 | 12:25 PM
babymac's Avatar
BOOST 4 LIFE!
Did you have any problems returning the afpr? And did you get a new one?
Old Apr 21, 2007 | 02:08 PM
t6378tp's Avatar
Turbo 3.5
naw they took it back with 0 problems and yes they gave me a new one
Old Apr 21, 2007 | 02:24 PM
Trust me I read. Still donesn't change the fact at even when he was 3mph slower from last 1/4 run, he was still running way to slow on the top end.
Old Apr 21, 2007 | 06:28 PM
babymac's Avatar
BOOST 4 LIFE!
Tom are still running your stock muffler?
Old Apr 21, 2007 | 08:04 PM
LA02MAX's Avatar
Read that again. His afpr went out mid way through the run, which explains why the car wasn't running right all the way through. He would have been in the 13s if it weren't for that.
Old Apr 21, 2007 | 08:19 PM
What you are not getting is that with his previous setup on 75 shot he was only trapping 92mph when he should have been trapping 97.5+. That in itself whats wrong.
Old Apr 21, 2007 | 08:23 PM
LA02MAX's Avatar
How was I supposed to know that, exactly?
Old Apr 21, 2007 | 08:35 PM
Don't know, thats your problem.
Old Apr 21, 2007 | 08:50 PM
LA02MAX's Avatar
Oh ok.
__________
Old Apr 21, 2007 | 08:57 PM
babymac's Avatar
BOOST 4 LIFE!
It was actually a 65 shot and he trapped at 94(still a little low for a 14.3). That was before he changed his b-pipe, so he should trap at the right mph now. The stock b-pipe was really holding him back imho.
Old Apr 25, 2007 | 03:37 PM
TAPOUT's Avatar
You will lose
When I was running an 80 shot of nitrous on my 4th gen, I was running 13.7@100. I was averaging 1.95 60 ft's on slicks, spinning. My 1/8 was around 8.7, and around 82-83mph. I was running similar mods to yours, except I had a mobiltek stage 2 valvebody. I think you are on the cusp of reaching the elusive 13.9X. What RPM are you launching at?
Old Apr 25, 2007 | 03:45 PM
babymac's Avatar
BOOST 4 LIFE!
I'm with him usually when he runs and he always get's 2.0's, so thats about as good as its going to get on street tires.
Old Apr 25, 2007 | 06:11 PM
t6378tp's Avatar
Turbo 3.5
no, y-pipe, high flow cat, 2.5" b-pipe and flow master muffler
Old Apr 25, 2007 | 06:14 PM
t6378tp's Avatar
Turbo 3.5
with my old setup I did not have a exhaust and my plug gap was too wide, these 2 things with both hurt your top end
Old Apr 25, 2007 | 06:20 PM
babymac's Avatar
BOOST 4 LIFE!
I know you have a y,b, and cat ..... I was just wondering if you had a stock or aftermarket muffler
Old Apr 25, 2007 | 06:21 PM
t6378tp's Avatar
Turbo 3.5
was that a 80shot with zex or nx, cause a 50shot with a nx kit is = to about a 75shot zex
I pull 2.0 to 2.1-60fts with the stock 205/65/15's @ 15psi but the tires are max'd out and I can not launch any harder without blowing the tires off the rim
I lauch from idle, I find this to work the best cause if I try launching at a higher rpm the tires will just spin
I am not really worried about it cause if the afpr did not die on the run I would have broke 13's
Old Apr 25, 2007 | 06:48 PM
t6378tp's Avatar
Turbo 3.5
yeah this may clear somethings up I ran a 8.95 in the 1/8 and the 1/8-1/4 convertor it says I would have ran a 13.96
Old Apr 27, 2007 | 11:26 PM
Imax00's Avatar
thats good bro. keep it up
Old Apr 30, 2007 | 05:45 PM
smotz's Avatar
Brain phuck
Sux I haven't hit 13.9s yet and my mph is 101-102 with 2.2 '60 foot on drag radials
Old Apr 30, 2007 | 07:13 PM
t6378tp's Avatar
Turbo 3.5
what shot are you running?
Old May 3, 2007 | 05:14 AM
smotz's Avatar
Brain phuck
75 wet nx ***
Old May 3, 2007 | 07:44 PM
babymac's Avatar
BOOST 4 LIFE!
perfect prediction
Old May 14, 2007 | 07:00 PM
Torgus's Avatar
get some headers...
Old May 14, 2007 | 07:48 PM
t6378tp's Avatar
Turbo 3.5
Originally Posted by Torgus
get some headers...
your late already broke 13's and without headers
Old May 14, 2007 | 09:36 PM
viper32909's Avatar
So are u consistently running 13's yet?
Old May 15, 2007 | 02:29 PM
t6378tp's Avatar
Turbo 3.5
yep 13.9's all day read ther post
I have a few problems to fix but once they are gone I am looking at 13.6 to 13.7's
Quickgtp
Aug 27, 2015 02:13 PM
vanebecker
Aug 17, 2015 08:24 PM
CIRCO
Mar 1, 2001 07:26 PM
yongjun
Jan 20, 2001 08:42 PM
