1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Wheel Spin??
Old Jan 31, 2010 | 05:23 PM
  #41
Grand_hustle17's Avatar
Originally Posted by sparks03max
The unbridled power of a 4th gen coupled with a 4 speed automatic transmission is incalculable. It's thus illogical to question even spinning in 4th gear.
Old Jan 31, 2010 | 09:17 PM
  #42
modenaf1's Avatar
What is illogical to question is whether or not you are spinning the tires or the Earth. If every 4th gen 4speed automatic Maxima owner couldn't keep their foot out of it in first or second gears, we wouldn't need daylight savings time anymore.
Now, seriously back on topic of someone brake torqueing to 2500 RPM in an automatic, unless the transmission is modified, that is higher than the stock stall speed on the converter. If that is the stock torque converter, there could be something wrong with either the converter or something slipping in the transmission, either way I would take it easy until the issue is addressed!
Old Feb 1, 2010 | 02:14 PM
  #43
aackshun's Avatar
In my short experience with the Maxima I have better luck dumping than slipping.
I rev above 2k but way below 2.5k, drop it like it's hot while I'm flooring it, achieved a 2.30 '60 with Potenzas @ 20psi, I also run 41 psi in the rears (max PSI).
As the day got hotter, I bogged the last run and I wanted to do a 2.2k or 2.3k dump.
Mods:
Bomz Intake
WSP Y
Magna Cat
UDP
Exedy Clutch
I had spinning issues until I lowered my psi down to 20, even then still had spinning till I did my quickie burnout, even though that goes against most people's advise w/ all season tires, the quickie burnouts help allot in telling me how the tires are going to hook up that run.
Good luck, takes practice, I was gettin 2.5 60's and now I'm knocking on the door of 2.2s
Just for lolz, here's my worst run to date due to wheel spin. (17.125 @ 87mph)
http://www.youtube.com/watch?v=XGVdZPbMSsk
Old Feb 5, 2010 | 04:33 PM
  #44
StenholmEngineering's Avatar
For your next set of front tires, try some 235-245 width that are known for good traction. If you want to go with something low priced, check out General Exclaims.
Even with all the mods in my sig, I barely spin in 1st gear with 245/40/18 exlcaims up front.
i jsut read up about these tires and they seem to have great reviews!!! i think im going to have to grab 2 for my fronts for this summer.....what do you think is the widest i can go fora DD?? btw i have a 00 SE!
Old Feb 8, 2010 | 09:51 AM
  #45
aackshun's Avatar
It depends on the rim.
Old Feb 9, 2010 | 12:31 PM
  #46
id be usin the stock 17s, i know some 245 would be great for the traction but can i DD on them??
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Redfox
Sep 28, 2015 10:41 AM
