1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
6th gen 1/8th mile times....blah
Old May 8, 2010 | 04:37 PM
jasoneon's Avatar
Car is a 2005 6 speed, all options, 75,000 miles, little over 1/2 tank of 93 octane and a fujita intake as the only mod. I'm really disappointed with the times. Had three 9.6's, one 9.7 and one 9.8. The slower times were with some wheel spin and 2.4 second 60 foots. The 9.6's were with 2.2 60 foot times. I tried various rpm's with and without the traction control on but couldn't get a good launch. I'm on stock size badyear tires and didn't mess with the air pressure any (32psi or so) I trapped 75.xx mph on every run, didn't miss any shifts, but let off between each shift. I was really expecting about a 9.0, but it just wasn't going to happen. It was in the 80's temp wise, not sure about the humidity. I did beat a friend's trailblazer ss 3 times, but it seems slow just like my car does. What gives?
Old May 8, 2010 | 05:29 PM
krazy6's Avatar
You need to get the 60' down and shift faster. I got a 1.9 60' on my pass in my sig and I don't let off the gas evvvvvverrrrr.
Old May 8, 2010 | 05:57 PM
NmexMAX's Avatar
dot dot dot ...
Any idea what the DA was?
Old May 8, 2010 | 06:22 PM
jasoneon's Avatar
I tried launching different ways, even with the traction control on and couldn't do any better. If I dropped the clutch from higher than about 2,000 it would spin and get a 2.4 60'. Tried letting it out slowly from 3,500 and it either spun or didn't spin and got a 2.2 60'. I don't think it's possible to shift faster unless you just flat foot shift it which I'm not going to do in something I rely on everyday.
No idea what the DA was but it was mid 80's and the track elevation is only 600 feet above sea level.
I did dyno it last year and it put down 230whp and 22x torque with the intake.
Old May 9, 2010 | 05:33 AM
tedo007's Avatar
faster than you think
Try doing slip you can easily get a 2.1 60ft.
Old May 10, 2010 | 09:20 AM
jkpgt96's Avatar
I was cutting 2.2 60 ft's on my Goodyears with 40 psi in them.
Drop some air pressure, and go from there. FYI, I don't see you cutting a 9.0 1/8th mile in a stock 6th gen with an intake. I cut a 9.0 @ 80 1/8th and went 14.0, so I doubt you replicate that in a stock 6th gen..no offense just a frame of reference..
Also, as mentioned...don't lift!
Old May 10, 2010 | 09:22 AM
jkpgt96's Avatar
This seem absurdly high to anyone else..? Not the torque, the horsepower..
Old May 10, 2010 | 11:27 AM
krazy6's Avatar
I went 9.0 @ 78 in the 1/8 when I was intake only.
Now I'm at 8.7 @ 80 in the 1/8 with an intake and a 3" exhaust.
Old May 10, 2010 | 08:51 PM
aquito's Avatar
i went 9.7 @ 74 in the 1/8 with my stock auto 05, half tank of gas and 2.4 60"
Lakersallday24
Nov 7, 2024 07:31 PM
Matt93SE
May 24, 2019 02:58 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
2k0to2k3
Aug 18, 2015 09:59 AM
MaxStock
Aug 12, 2015 08:33 AM
