1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
New Personal best...Wish it was better.
Old Oct 30, 2010 | 04:42 PM
jr schultz's Avatar
These times were on my new Nitto NT555R drag radials with 16X8 RX7 wheels.
Only 2 passes today. The track was very busy. I burned out the same. I would go to the edge of the water box and burn out in first gear for about 4 or 5 seconds. I tried two different tire pressure amounts.
1st pass at 20 PSI 2nd pass at 15 psi
60 Ft - 2.234 60 Ft - 2.196
330 - 6.16 330 - 6.178
1/8 - 9.34 1/8 - 9.42
1/8 MPH - 78.38 1/8 MPH - 76.7
1/4 - 14.44 1/4 - 14.63
MPH - 96.59 MPH - 94.29
What I don't get was that my second pass had a better 60 ft, but everything else was slower. Maybe I should try to learn how to get a perfect launch at 20 psi tire pressure.
I need practice! I was hoping for 13's. I'm going to try and go back in November before our track closes down for the winter.
Old Oct 30, 2010 | 04:48 PM
NmexMAX's Avatar
dot dot dot ...
Temps? Do you know the DA? Nice times and good MPH. Cut out?
Old Oct 30, 2010 | 05:39 PM
krazy6's Avatar
Do you know the DA?
It is gonna be hard to run 13s with that mph. It's possible, but you will need a great 60ft.
Old Oct 30, 2010 | 07:03 PM
jr schultz's Avatar
Temps: 60. DA: 1158. Cut out open. The funny thing is that the da calculator said I could have run a 14.2 The last time I ran it was in 90 degree summer heat on street tires, and the da calculator said I could have run a 14.1...Go figure. I think I need practice finding the sweet spot with the drag radials. Maybe I'll get NWP Spacers to round out my bolt ons.
Old Oct 30, 2010 | 10:25 PM
krazy6's Avatar
That's pretty good DA.
Good luck next time man!
Old Oct 30, 2010 | 10:41 PM
Nealoc187's Avatar
SLOW
2 passes isn't enough to make a determination on what tire pressure you should be running. make some more passes and keep notes and you'll start to get a clearer picture of what you should run your tires at.
Old Oct 31, 2010 | 10:58 AM
Rods03Max619's Avatar
Nice times wish I had a track near instead of 1/8 and all the stupid regulations helmet and $hit!!
Old Oct 31, 2010 | 02:19 PM
krazy6's Avatar
What 1/8 are you talking about? Irwindale?
Pretty sure you need to run faster than an 8.6 to need a helmet.
Are you running faster than that?
Old Nov 1, 2010 | 08:34 AM
Grand_hustle17's Avatar
Next time try not to burnout... aren't you on street tires???.... I believe my times were similar when I dynoed 238whp
Old Nov 1, 2010 | 08:55 AM
tookrzy4u192's Avatar
Old Nov 1, 2010 | 09:11 AM
krazy6's Avatar
He will definitely want to do a burnout.
The nitto drag radials are the best when you get them really hot.
Old Nov 1, 2010 | 11:22 AM
jr schultz's Avatar
I need to adjust my e-brake. It wouldn't hold very well when I tried to burn out. The car would start pulling forward almost immediately. Also, with an auto, is it best to hold the brake down and rev it up a bit before launch or should I leave off idle speed? I was holding the revs up a bit, which is what I did on street tires.
Old Nov 1, 2010 | 04:40 PM
krazy6's Avatar
It will take some experimenting. Every car is different.
One of the best mods you can make is seat time.
Old Nov 1, 2010 | 07:29 PM
Srry I misread where he had radials.... tires aren't really that beneficial to auto's as you can pul 2.0's on street tires and really can't launch much higher than 2.2K... do a bit more justice with an upgraded TC
Old Nov 1, 2010 | 10:12 PM
krazy6's Avatar
Yeah, a higher stall would definitely help him.
Old Nov 2, 2010 | 06:40 AM
jr schultz's Avatar
I've been thinking of that. I know Aaron from NWP says that should be an auto's first mod. I'm curious how expensive it would be to upgrade.
Old Nov 2, 2010 | 04:36 PM
krazy6's Avatar
I would agree with that.
If you don't know how to do the swap yourself it will get really expensive.
Check out edge converters, that's what Aaron and Jime run.
Old Nov 2, 2010 | 05:53 PM
t6378tp's Avatar
Turbo 3.5
and Harold
Old Nov 2, 2010 | 06:32 PM
krazy6's Avatar
Originally Posted by t6378tp
and Harold
Oh yeah.
Old Nov 3, 2010 | 11:30 AM
jr schultz's Avatar
Cost of edge Racing 2800 Stall Torque Converter? My buddy is a mechanic, and he will help me install it. I need to save up for this.
Old Nov 3, 2010 | 11:47 AM
grey99max's Avatar
LandShark has Cosworth
About $450 - ask for Andre at Edge.
Old Nov 3, 2010 | 04:32 PM
jr schultz's Avatar
That's very reasonable. If I add more mods that will be the one. If I can some how get to the 13's with my current set up, then maybe I won't do it. I have to decide if I will be happy with 13's or if I will just continue until I get to 12's...We'll see. Anybody remember what a higher stall converter took off your et?
Old Nov 3, 2010 | 04:52 PM
read post #1296
http://forums.maxima.org/all-motor/5...thread-33.html
there will be a new stall converter if everything goes as planned.. it'd be worth the wait if you go that route
Old Nov 3, 2010 | 05:16 PM
jr schultz's Avatar
Originally Posted by tookrzy4u192
read post #1296
Nice! Stay tuned I guess.
Old Nov 3, 2010 | 07:29 PM
krazy6's Avatar
In my opinion I would go higher than a 2800rpm stall.
I would go with something around 3600-4000rpm.
Old Nov 3, 2010 | 07:40 PM
jr schultz's Avatar
Would that high of a stall be annoying on the street? I want a happy medium between street/strip for sure.
Old Nov 3, 2010 | 07:54 PM
krazy6's Avatar
Aaron said that he didn't even notice his 3,000 stall. I think a 3600 would be a nice compromise.
Old Dec 1, 2010 | 07:03 PM
Toxic99's Avatar
Too little of air pressure in a tire (esp drag radial) will slow you down and will be noticable in the mph. So Id say stay around 19-22psi and practice your launches.
Old Dec 1, 2010 | 09:58 PM
Gemner's Avatar
those drag radials work best in the 12.5-14 PSI range in my experience. However, they are just crappy drag radials
Old Dec 3, 2010 | 10:28 AM
jkpgt96's Avatar
238whp, and only a 96mph trap...?
Old Dec 3, 2010 | 01:17 PM
jr schultz's Avatar
Me? I have 233 WHP, but that was during the dyno tune session. I have no idea what gear the car was in when the computer posted that figure. But, yeah, 96MPH trap.
Old Dec 3, 2010 | 07:27 PM
Gemner's Avatar
auto, still low but explains a bunch of it. my bet is atmospheric conditions account for the rest
Old Dec 6, 2010 | 12:44 PM
jkpgt96's Avatar
11XX DA is pretty good...even with that DA and an auto...still seems low.
TallTom
57
Oct 14, 2025 05:16 PM
Mar 12, 2020 12:06 AM
REDinLV
Sep 28, 2015 12:31 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
pears
Sep 18, 2015 05:25 AM
