power doorlock problems
Old Feb 19, 2003 | 06:43 AM
jayrebb's Avatar
i drive an 85, ive noticed that when i hit the lock or unlock it doesent lock or unlock the driver side door. also, when i unlock the driver door using the key should it unlock all other doors?? it doesent. i was also hoping somone could tell me how difficult it is to install a keyless entry/alarm, i have a pretty good understanding of electronics and wireing. thanks guys.
Old Feb 19, 2003 | 07:49 AM
alllw86's Avatar
Re: power doorlock problems
Sorry to tell you but that's how it works. My 86se works the same way since new. Don't really understand why Nissan designed it that way.
Yes, you could add a remote power doorlock option. You have to add a driver side door actuator, since it doesn't have one. The doors/trunk locks have a magnetic switch on the locks used for the build-in alarm. You have to deal with the one on the driver side door when adding that actuator. It can be done just takes some work.
Another option is to disconnect the build-in alarm and install a new system. I always wanted to add a remote door opener but just never got around to it.
The choice is yours, I say go for it.
Good Luck
AL
Old Feb 19, 2003 | 08:48 AM
GundamWZero's Avatar
And if you've noticed, you can lock all the other doors with just the drivers side lock. It is the master lock, I believe. Also, if you have the factory alarm, If you set off the alarm, you have to reset it from the door you opened it from. .............cool!
Old Feb 23, 2003 | 10:20 PM
blackmaxima88's Avatar
yeah, I can lock all other doors by just locking the drivers side door with the **** or key....but I can't unlock all the doors with the key like I'm supposed to be able to on the drivers side...but I can do it from the passengers side. anybody have a cause for this?
Old Feb 23, 2003 | 10:41 PM
maximase86's Avatar
I love lamp.
Depends on what trim you have. If you have the GL or GXE, they have that ability. That's because they have the keyless entry. If you have an SE, they do not get that feature.
S
Old Feb 23, 2003 | 11:01 PM
have the SE, but the manual says I should be able to lock AND unlock all doors from the drivers side keylock. I can lock all doors by turning the key, and the factory alarm system is set, but then I can't unlock all the doors when I turn to unlock, and the alarm doesn't deactivate.
however if I go to the passengers side and turn the key to unlock, all doors unlock and the alarm is deactivated.
weird. and inconvenient.
Old Feb 24, 2003 | 10:03 AM
maximase86's Avatar
I love lamp.
Yeah, I think that what I said only applies to the 85-86. 87-88 got the feature. You may have a switch going bad on the drivers door for that to be happening.
S
lowpost99
Oct 26, 2025 06:53 PM
DJLAX152
May 4, 2021 11:46 AM
markevans999
Sep 10, 2015 04:29 PM
slowlifer
Sep 8, 2015 05:53 AM
trungg86
Sep 4, 2015 04:58 AM
