Digital to Analog Dash Conversion
Old Feb 24, 2003 | 10:34 AM
withstrings's Avatar
I just found this great webpage TODAY....
I have a 86 Maxima and a 78 280Z that have given me some great times and No, neither are for sale
Anyhow, there is a "Pick-a-part" salvage yard in town with 9 - Gen 2's and Gen 3's almost complete. just looking for us to reincarnate!
But, I have had a few problems with my digital gauge cluster and computer especially fuel levels, I replaced the float/filter assembly but to no avail.
Has anyone out there swapped the Digital Gauge for an Analog???
If so, what all did it entail?
Thanx
86 Maxima GL
16 x 8 + 225/55-16
K&N + Pacesetter
2-DIN (1992)Bose/Nissan Cass/CD
Old Feb 24, 2003 | 11:52 AM
Charles Bisel
No one that I know of has done that swap and I've been on these boards for over 2 years.
It would be extremely difficult to do the swap, as you're going to have to change out the sending units and all kinds of other stuff.
You should be able to pick up a digital cluster at a salvage yard for around $100. If you don't have a junkyard near you, check out http://www.car-part.com you can call one of the junkyards that has the digital instrument cluster and have them ship it to you.
-C-
Old Feb 24, 2003 | 12:11 PM
Re: Digital to Analog Dash Conversion
I called the wrecking yard and was told $25.00 for a Digital replacement, but out of curiousity...I asked about the conversion and was told it has been done before.
I would need a gauge cluster, in tank fuel pump/sending unit assy,
new o-ring and small harness. All for $100.00.
I'm a little skeptical, but willing to give it shot to see what happens.
Let's see if my Electrical Apprenticeship Pay Off
Thanx
Old Feb 24, 2003 | 12:17 PM
maximase86's Avatar
I love lamp.
Re: Re: Digital to Analog Dash Conversion
Thanx
Unfortunately C is right. You can try to see if it may work. Most likely your going to have to change some sending units.
S
Old Feb 24, 2003 | 01:36 PM
MaxWgn's Avatar
Thanx
I know the fuel level sensor is different. The oil pressure sensor could also be different, as well as the voltage and temp...but not 100% certain. Even if the sending units - except fuel - are the same, some things would need to be changed...I'm sure the harnesses are a little different, etc...
If you go to the trouble, and everything works, by all means, let us know...I don't have the digital cluster, thank God, but a lot of us do, and would love to do the convo...
Old Feb 24, 2003 | 02:04 PM
Re: Re: Re: Digital to Analog Dash Conversion
I have located a 1986 Digital and 1986 Analog Schematic, and am having them burned to transparencies to see if there are any differences,
and I'll hunt down the part numbers to see if there are any changes as well...there was a big layoff for a lot of US builders/skilled craftsmen so I've got a little time on my hands
Time to get a little dirty and pull some hair out.
I'll share with youse as soon as I get it operational.
Hey folks, this is a great Forum and I am glad to be a part of Ya!
Thanx
Old Feb 24, 2003 | 11:14 PM
dr.disc's Avatar
Re: Re: Re: Re: Digital to Analog Dash Conversion
Thanx
This is a frequent modification in the Z31 Nissans. Gen 2 Maximas are very similar in this respect. You need analog engine sensors, a speedo cable, an instrument module, a dash subharness, and analog fuel sending unit. There is an instruction on Z31.com website in the modifications section. It is the same procedure.
Old Feb 25, 2003 | 02:22 AM
Hey Dr. Disc:
I searched the modifications section and I couldn't find the article
you spoke of, where did you say it was again???
I bought the cable, gauge cluster, subharness, fuel sending unit/pump assembly for $80.00 earlier today, but I need to know about those engine sensors.
Thanx
Old Feb 25, 2003 | 01:27 PM
dr.disc's Avatar
Hey Dr. Disc:
Thanx
Do a search on the site. I forget just where I saw it, but it is there. Use "digital to analog dash conversion". Or ask on the site message board. But you're most of the way there, now. Oil pressure sender, cylinder head temp sensor (not CHTS). I think that is it.
Calabar
Oct 5, 2015 09:57 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
