no spark from ignition coil
Old Aug 9, 2003 | 09:46 PM
adroga's Avatar
My uncles 87 maxima doesnt have any spark in the spark plugs or coming from the ignition coil. What could this mean? The ignition coil was replaced and nothing changed.
Could there be some connection to the timing belt?
Any guidance is appreciated.
TIA
Old Aug 11, 2003 | 02:41 PM
maximase86's Avatar
I love lamp.
Possible that you have either a bad ignition coil or power transformer, bad distributor cables, or a bad crank angle sensor. I would test all those. Also you might want to go ahead and pull codes from the ECU. If it's throwing a code, it will help you pin point the problem.
S
jmlee44
Oct 2, 2022 02:13 PM
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
