A Few Maxima Questions
Old Feb 15, 2001 | 03:12 PM
dc17h21o4n's Avatar
Hi I have a 1985 NON SE Maxima auto with around 114k. I have a few questions about some nagging problems.
1.Initial Acceleration from a stop has a slight lag in it, I normally run 89 octane in it, but when gas was really expensive last summer and i put 87 in it for a while and it ran horrible with that in it(I also had a huge whole in my muffler at the time). Could this be fuel injectors, or could a tune up fix this. I have had it for 10k and have not had a tuneup not including air filter and oil changes. It accelerates fine if it is already moving, maybe it's a low rpm thing.
2. At speeds between 55-65 especially at 65 every once in a while(I think it occurs more often with OD on), and I step on the gas to go faster it hesitates also a few times before it speeds up instead of speeding up smoothly. I don't have my car here at school, but I think that the accelerator pedal would also pulsate when it was hesitating.
3. I have had two incidences with the sunroof refusing to close, it opens without a problem. The last time i used it it took approx 10 seconds for it to decide to close. I know sunroofs are expensive, but what part could this be?, the motor perhaps, and how much would it cost?
4. My Mom's car got hit by a stupid plow truck backing up, so she borrowed my car for a while, but she accidently broke my stock volume **** on the radio. I superglued it back on for now. I have a DIN Pioneer Tape Deck from my old car. Would that install with a lot of hassle?, because the stock deck has the tapedeck plus the equalizer and clock below it.
5. I know it has a 4 wheel independent suspension, but a friend noticed that the shocks or struts were pretty bad. I forgot which ones he said.
Which ones do I have, and what would be an approximate cost to repair those?
Thanks for your help,
David
Old Feb 22, 2001 | 05:01 PM
tom200K
I have an 89 w/ 204K on it. My first guess would be general tune-up items, especially the Oxygen sensor (the sensitivity to octane is a clue) and the fuel filter. BTW, I've never had the injectors cleaned and they work fine. There may be a transmission problem.
It sounds like you bought the car used. Look at the fan belts. If they looked cracked, there's a good chance it needs a timing belt. Expensive but necissary.
The sunroof may need some good lubrication.
Try to be optimistic. It seems with Maximas, the expensive sounding symptoms have inexpensive fixes.
Tom
David
Old Feb 22, 2001 | 11:40 PM
maxima561's Avatar
i am taking out my factory radio and equilizer out. Maybe we could work something out in a few weeks
MikesChevelle
Aug 10, 2015 10:53 AM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
xUNIxPanther
Aug 5, 2015 09:31 AM
