My car is stuck in reverse?
Old Jan 14, 2004 | 05:40 PM
blahblahblah's Avatar
'88 5 speed is stuck in reverse? It was working fine 30 seconds before it got stuck, what the hell. I reversed it then went into first and then reversed it again and when I tryed to pull it out it, it was suck and I cant get it out. One thing I noticed is the the support rod for the shifter had a bolt missing so I was thinking the coupling got bound or something? My uncle said it could be the throw out bearing but I dunno? Any one ever had this happen?
Old Jan 14, 2004 | 06:36 PM
maximase86's Avatar
I love lamp.
Hmmm is this on the tranny you just rebuilt or are still rebuilding? A throw out bearing is possible, but usually if a tranny is locked in gear, the car is in motion and the clutch is engaged. The car would still want to move in reverse even with your foot on the ground. Still possible, but I don't think it'll cause your problem. I would think that it's more of a shift linkage binding somewhere, albeit internal or external. On the 4th gen auto to 5-speed conversion, we had a problem with the tranny being locked into neutral before we put the tranny in the car. Turned out one of the shift forks had moved during shipping and got engaged in gear and it binded up the rest of the shifting assembly.
S
Old Jan 15, 2004 | 03:00 PM
I was kind of thinking the same thing. Its not my transmission, it is one out of a car I want to buy for parts. It was working fine, then he got stuck in the snow and got it stuck in reverse he said. Its making a funny burning smell too when its running, like burning metal? I think it was the clutch, but im not sure
Old Jan 20, 2004 | 06:18 PM
All fixed I wil be driving my max again within the next few days!! Its been about a year since I parked her. Now I have a second engine to work on and build up for a turbo. Should be fun.
Old Jan 20, 2004 | 07:02 PM
maximase86's Avatar
I love lamp.
All I can say is, VG33ER crank and pistons. You'll up the displacement 3.3liters, and lower the compression a little for boost. With a S/C your good for about 210hp and maybe 230 tq at the crank with 8 psi or so. With turbo 8psi....maybe 225-230hp and 240tq at the crank.
S
Old Jan 20, 2004 | 07:56 PM
Any idea where I can pick these up at? I cant find any pistons or rods except for the Z32. No old 300zx ones.
Old Jan 20, 2004 | 07:59 PM
What, pistons and crank from a xterra? You sure these will work? What is the compression ratio? I was shooting for a mid 8, low 9. Something where I can push higher boosts like maybe 15-20.
Old Jan 20, 2004 | 08:15 PM
maximase86's Avatar
I love lamp.
Yeah, its the crank from the Xtrerra/Frontier, from what I seen, the block is the same, bores are the same, but the stroke is a little longer on the VG33ER. Also the ER has the dished pistons with the lower compression. Probably the same 8.1 cr compared the stock 9.1 the VG30E has. If you want to do higher boost like you mentioned, the dished pistons and lower cr is a must.
S
Old Jan 25, 2004 | 02:23 PM
Well she runs. I am still a little weary about the transmission. I dunno, I have ran into so much trouble that I dont want to start celebrating yet. One thing I just noticed is that neither of my radiator fans are running until the thermostat turns them on. From what I understand one of them should be running all of the time right? Other than that I would say that everything is peachy keen *so far*. No leaks to speak of yet, idles a little rough but it seems like it was doing that before. One thing that I did notice is that the new clutch makes noise when I engage it. I dont remember it doing this before. Kind of a quiet thud and a rubbing sound. I am thinking it is just because everything down there is new and it needs to be broken in a little?
Anyway, later.
Old Jan 25, 2004 | 02:37 PM
keith_u's Avatar
Anyway, later.
I thing the fans only turn on and off cause neither of mine run constantly. Unless mine are broke too lol
Old Jan 25, 2004 | 02:40 PM
do yours make a ton of noise when they turn on? Mine are really loud, it gets really annoying in the summer time.
Old Jan 25, 2004 | 02:52 PM
keith_u's Avatar
yeah the first time i heard them kick on after I bought the car I thought it was going to fold out wings and fly off
Old Jan 25, 2004 | 06:11 PM
maximase86's Avatar
I love lamp.
Well, my fans remain off unless the engine temperature is to a certain point, then they turn on. Mine are pretty noisey especially if both are on.
As for the rubbing or thud noise....it could be some play in the clutch pedal, or you could have some mounts that are loose or going bad. I'd look into em.
S
Lakersallday24
Jun 16, 2019 01:35 AM
spidgeon
Aug 18, 2015 05:46 AM
Trin1j23
Aug 12, 2015 08:31 PM
Derrick2k2SE
Aug 12, 2015 06:47 PM
Balkins
Aug 12, 2015 06:39 AM
