!chts!
Old May 23, 2004 | 06:06 PM
trinitykt133's Avatar
!chts!
ok this is really starting to buggggg me. i've been looking online trying to find the cylinder head temp sensor and im not having any luck. the only thing i've found is "water temperature sender- for guage" and "water temperatrue sensor-at cylinder head". is the chts alsor known as a a water temperature sensor? if not does anyone know where i can get a new one with the 7 inch connector online? thanks for any helpt
-matt
Old May 23, 2004 | 09:18 PM
maximase86's Avatar
I love lamp.
The CHTS has nothing to do with the coolant system. It doesn't even measure the coolant temperature level. It's a temperature sensor that measure the cylinder head temp. You might want to try Courtesy Nissan for the harness and sensor. Even though they are a dealer, I think they still discount the price if your a maxima.org member.
S
Old May 24, 2004 | 09:40 AM
Drjmaxx88's Avatar
I think you have to get this part from the dealer.
The CHTS is part #22630-01P01 thats for the sensor
The harness is 24078-16E00
You should pay about 50 bucks for both.
I just had this done to my car about a week ago.
Old May 25, 2004 | 11:26 AM
alright. thanks for the feed back
um this one is gonna be a tough one. is the chts supposed to have power when the car is not running. i tested the harnass coming from the computer and it has 5V when the ignition switch is on, but when the ignition switch is off the power to the sensor shuts off. i've heard before the chts is supposed to be all time hot from the computer so it already has an acurate reading when you go to start the car. i'm not sure about this so hopefully one of you guys can set me strait.
also check this out. http://www.tomco-inc.com/Catalog/10e...%20sensors.pdf
i googled the model numbers you guys gave me for the sensor and got this .pdf back. it has the number on page 27 and lists it as a "cts" colent temperature sensor?
also this site http://carburetorexchange.com/ectcatalog.pdf
lists it on page 16 as follows
1984-1988--300zx,maxima--all engines--3.0L(vg30)--22630-01p01(Head Sensor)
also listed as a coolant temperature sensor??
according to these two documents they are the same sensor but in vg30e they just bolted it into the head instead of puting it near the antifreze. now I'm really lost
-matt
delerium75
Nov 4, 2012 02:09 PM
richard_85zxt
Apr 23, 2010 02:27 PM
madgun68
Aug 3, 2009 01:13 PM
4togrfr
Jan 26, 2007 11:15 AM
