Air Condition Problem
Old Jul 4, 2004 | 08:03 AM
marcdathug's Avatar
For some weird reason my air conditioner just stopped working. I checked all of the fuses and they are all okay. The only way I can get the A/C compressor to come on is to take a wire and jump it across the fuse relay. I checked the switch on the inside I didn't see anything that be causing a problem. I also attempted to recharge the A/C but that still didn't solve my problem. I was just wondering if anyone has any suggestions to what the problem could be. Thanks.
Old Jul 4, 2004 | 04:52 PM
maximase86's Avatar
I love lamp.
Wait...you tried to recharge the system? With what? These systems run on R12...which isn't available to the normal consumer....unless you have a hookup with someone. I'd try replacing the relay...sounds like it's bad.
S
Old Jul 5, 2004 | 07:03 AM
marcdathug's Avatar
i had to get all of the R12 out of it and then switch it over. I got an extra relay and it still wouldnt work. how many relays are there for the a/c?
Old Jul 5, 2004 | 11:34 AM
maximase86's Avatar
I love lamp.
You do realize if you switch over to R134a, you're going to need to replace the dryer.
S
Old Jul 6, 2004 | 06:24 AM
MaxWgn's Avatar
when you push the A/C button, does the compressor even cycle on? If not, it could be a problem with the clutch, or the same problem I have - the control unit is bad - i need to replace mine...
The control unit I'm referring to is the actual header, witht he fan speed control, the A/C button, etc...
MAXSE5SPD
Sep 17, 2022 04:00 AM
Maxima30
Sep 7, 2015 06:13 PM
intimidator
Sep 5, 2015 07:23 PM
sdotcarter
Sep 2, 2015 09:53 PM
egali045
Aug 5, 2015 09:02 AM
