List your mods!
#83
Since I took all the EGR crap out of my car, this opened up a whole bunch of space on the drivers side of the engine compartment. I mounted a large windshield washer tank as the source of the liquid. How long does it last? Lots of variables on this one: jet size, pump flow rate, trigger point (at what PSI does it kick in), how heavy is your foot. :-)
#88
Originally Posted by Big_E-Dog
hey you guys what is the screw on the base of the distrubitor called and what is it for?
#89
Originally Posted by cardana24
thats the screw that you use to set your timing. Shine a timing light in there then loosen the screw and the the dis, clockwise or counter-clockwise to get your timing set where you want it then tighten the screw back down. Don't tighten it down too much though, I snaped the head off of my screw and it was a pain to get out.
S
#90
btw speaking of timming, i need to set myne, ( i played with it and i think its not helping on gas) so i wont to get it set right, mabey not factory but right, i do have that da** tic tic at idle
i might buy a timming light today depending on $$$$$$$$$$$
#92
#94
Originally Posted by wylie-c
The timing isn't going to stop it from going 'tick,tick'. It's probably the hydraulic lifters ticking. What's your oil pressure at idle? And what weight oil is in there?
10w30 at idel its ummmm (i changed the gauges out i had the 90 120 psi ones,i guess its like 20 idk
would 10w40 help??? i use castrol gtx high mileage, with K&N oil filter
#97
Acronym ?
[QUOTE=maximase86;2892359]Most people know my mods, but I'll list them again.
maximase86
86 SE, 5-speed
Intake - Full CAI
Exhaust - 2.5" Cat-Back, Stillen Exhaust with single 4" tip
Engine - Unorthodox Racing UDP, 300zx ECU, Lots of Wireloom
Tranny - 3rd Gen 5-speed
Suspension - 3rd gen FSTB, 3rd gen Eibach with 1.2" drop, KYB GR2's, Addco RSB
Exterior - Dark Red Metallic, color-keyed mirrors, grill, lights, bumpers, and airdam. 5-lug conversion, 18" TSW Trophies with 215/35/18 Yokohama Parada/Parada Spec II rubber, 15" 97 I30 Rims with 205/55/15 BFGoodrich Traction T/A rubber, PIAA Lighting throughout, clear front turnsignals with amber bulbs, amber cornering lights
Interior - Clear courtesy lights with superwhite bulbs, brush aluminum dashkit, Reverse indiglo gauges (since removed since they stop working)
Audio - Kenwood Excelon HU, Components, and subs, PPI Amps.
Coming soon: Running engine (VG30ET?), KALSC Turbo Kit, Crossdrilled/Slotted Rotors maybe.
Can you explain to me the acronyms ? Sorry I'm new to this
I'm looking into the suspension swap from 3rd gen.. what do you have.
maximase86
86 SE, 5-speed
Intake - Full CAI
#98
[QUOTE=Chrismkellyjr;9134060]
first no point in doing a 3rd gen suspension swap unless you want to go 5 lug, it's the same type of parts other then the hubs, read though the suspension sticky for more info..... the acronyms like CAI= Cold Air Intake, UDP= Under Drive Pulley FSTB= Front Strut Tower Brace
maximase86
86 SE, 5-speed
Intake - Full CAI
maximase86
86 SE, 5-speed
Intake - Full CAI
#99
but now that you brought this back up
short ram intake
coil overs all 4 corners
currently rolling on G20 rims
500lb/in springs all the way around
updated sound system with single 12 sub
more will be done once I get my S12 up and running
short ram intake
#101
I know this is an old thread, but like a classic car I like to keep 'em alive.
1987 Maxima Mighty Max (what a lame name for such an awesome car).
All stock and mostly going to stay this way. I say mostly because once I locate all the interior parts that I need I have the following audio system ready to install:
Sony RSX-GS9 Hi-Res Digital Media Receiver w/ Bluetooth
MTX Audio 15" T9500 Series T9515-44 Subwoofers
4000W.
Two Cerwin Vega SPRO1400.4
1400W Stroker Pro Series Amplifiers.
Rockford Fosgate Punch Pro PPS4-10 700W 10" Midrange Speakers.
Rockford Fosgate Power T1T-S
1" 150W Power T1 Series Dome Tweeters.
4000W.
#102
87 Maxima
Swapped auto for manual
Right now I have a set of 1989 exhaust manifolds. Problem is the rear manifold covers the oil filter mounting spot. I relocated the oil filter but pressure is taking too long to come up. All the 2nd gen manifolds I have ever seen have the front manifold cracked. I'll just have to braze one and run with it.
Why are people putting Stanza throttle bodies on Maxima? Stanza are 4 cyl. How is that better?
I would probably update the radio head unit but I don't see a dash kit listed and don't want to hack the job.
hazepurple
24
12-26-2006 03:26 AM
