Shudder?
Old May 19, 2005 | 07:55 PM
E-CARP's Avatar
Shudder?
Ok, I've got this shudder when starting from a dead stop, or accelerating from 5mph, as going arround a corner. The propeller shaft seems to be tight, IE no loose u-joints. Could it be the center support? It's an '84 maxima wagon, 167,000 miles,coil spring rear, with the damper missing, but a solid bar replacing it which did nothing for the shudder! Earl
Old May 20, 2005 | 09:12 AM
maximase86's Avatar
I love lamp.
Could be time to change the tranny fluid.
S
Old May 21, 2005 | 12:38 PM
E-CARP's Avatar
change the tranny?
S
I know the tranny dosn't slip, so I've already counted that out. I need to jack it up, and run it and see if I can duplicate the rumble while under it, and someone inside applying the parking brake, and giving it some gas at the same time. I think I'd be able to find it! Earl
Old Jun 10, 2005 | 10:07 AM
E-CARP's Avatar
shudder
S
I checked the driveshaft with the car on a lift, and the axle suported, and found the front u-joint is worn! I'm looking into a local shop that can replace a "non replacable u-joint" Has anyone done this with good results? Earl
:attention
Old Jun 13, 2005 | 07:00 AM
MaxWgn's Avatar
They are staked on - a good driveshaft shop can do it...in some cases, they can "rework" the OEM shaft to accept normal, replacable U-Joints...they did it for my dad's on Pontiac wagon...
Old Jun 13, 2005 | 08:04 AM
E-CARP's Avatar
u-joints
I was quoted "arround $200.00" to replace the 2 yolks on the front driveshaft by a local shop, then checked on line at "driveshaft specialists Inc." and they build a complete new driveshaft, center bearing, and greasable u-joints for $239.00 with free shipping. Thats the way I'm going to go, if I can't find a good front 1/2. Earl
Old Jul 6, 2005 | 11:26 PM
SuperWario's Avatar
sweet **** dude
Old Jul 8, 2005 | 03:10 AM
belakithom's Avatar
That's cool, that you were able to repair it for so little, Ecarp:}
Old Jul 8, 2005 | 01:56 PM
E-CARP's Avatar
Driveshaft
The new one piece shaft is in, and gone is the rumble! It makes one wonder why Nissan used a 2 piece, with a support bearing to begin with, as a 1 piece fits without a problem????
JMag90
Aug 25, 2015 09:17 AM
NisMax615
Feb 11, 2003 06:42 PM
Joseph77
20
Jan 25, 2003 12:23 PM
bidnizman
Aug 10, 2002 04:07 PM
SCCA Solo2
Mar 23, 2001 10:23 AM
