starting issues
starting issues
my car hasnt been starting...it stopped starting back
in april and i kinda just left it there..it atempts
to start but it dosent turn over...i remember someone
saying to spray intake manifold cleaner into the
throttle body.. so i tried that today and it
worked..the car ran for about 6 seconds then it shut
off...i kept doing it a couple times and the ran for a
few seconds off of the intake cleaner..
...i then tried starting the
car witout the cleaner and it ran for about 1
second...any ideas on wuts rong with my car...my friend said my fuel pump may be bad or my injectors...
thanks for any responses
Originally Posted by ray_289
yea just cheked and i hear the pump come on..
ware is my fuel filter located...ware is the coil located and wut does it look like...iam new to all of this...
thanks
thanks
![hide](https://maxima.org/forums/images/smilies/hide.gif)
if you cannot find the fuel filter, follow the fuel lines
also if you pick up a haynes manual from advanced auto that would probably help you out a lot.
k i found da coil and i made sure the wire was tight...ware on the fire wall is the fuel filter located(like drivers side or passenger side) and wut does it look like...and how would i tell if its bad...sorry for any stupid questions
i was playina round with the car today and i got it to run for a good 30seconds but it was running off of the intake cleaner...so i take it the car is not getting any fuel...so iam pretty sure its the fuel pump..fuel filter or somtin to do witht he injectors
any ideas
any ideas
thanks...how would i check the fuel filter to see if its bad or not...also i have a feeling its the fuel pump because when i turn the key to the ON position i hear the pump come on but i dont hear the hissing sound of the fuel moving that i ussaly would hear..
how much and how hard is it to change teh fuel filter...my uncle who is a mechanic is coming over tommorw so he'll be able to help me out...is there anything special i should ask him to check?
![Tard smash](https://maxima.org/forums/images/smilies/smashfreak.gif)
changing the fuel filter is not hard, if you do not mind getting a little gas on you
![GrinNo](https://maxima.org/forums/images/smilies/grin_no.gif)
Originally Posted by cardana24
If he is a mechanic then ask him why your car won't start
changing the fuel filter is not hard, if you do not mind getting a little gas on you![GrinNo](https://maxima.org/forums/images/smilies/grin_no.gif)
lol good idea cardana...thanks for the help...he'll be here by tommorw afternoon
my uncle was here...and he said the fuel pump is the problem....he said to take off teh cover for the fuel pump and sand down the corrosion on the pump and see if that works if not change the pump...i sanded the corrosion down..but still the same problem ..i didnt wanna mess with the wires cuz i was unsure whether they come out or not... is there anything else i can do to it to see if i can get it working before i buy a new pump?
thanks
thanks
i kno y it wont start..the fuel pump is bad or somtings rong with it...iam asking wut are things i can do to check it to see if it can be fixed..like how my uncle said to sand down the corrosion iam wondering if theres any thing else i can do besideds that
dats true...ill have to hit uip a junk yard around here sometime then...any idea how much it should cost...i dont want to be over charged
![bustedrun](https://maxima.org/forums/images/smilies/bustedrun.gif)
j/k, I can't imagine it costing very much. I have never bought one used but I would get maybe $10?
I would also check the plugs to see if they are fouled. I have a first gen that I got and I had to use starting fluid to get it to start a little. I pulled the plugs and they were coated with oil! If this is the case, then you should clean the plugs or get new ones. If the engine fouls them again, as was my case, then get some anti-foulers and put them in something like cylinders 1-3-5 or 2-4-6 (you can only put them in half the engine's cylinders). Start it with some fluid and then just keep it going and take it for a trip of about 10 miles on surface streets (it worked for me) with the RPM's in a high range, as in not shifting into 4th gear and staying in 3rd. After that if the other plugs in the engine stay clean, you can remove the anti-foulers.
I did that, the motor now will start fine and the plugs are clean.
has anyone changed there fuel pump before...theres wires that go from the pump to the car and i have no idea how to take em out..they dont budge at all when i try to move them and i dont wanna damage the wires...any ideas?
i found my dads old chilton manual and it helped me out
i disconnected the wire...and i got 4 of the 6 bolts out...but one of the bolts are in a tight spot and it got stripped a lil bit while i was trying to take it out..any one have any idea on how i can take this bolt out with out stipping it completly? other than the bolt problem i dont have any other issues with taken the pump out
87 nissan for sale
hey all, I have an 1987 NIssan Maxima..silver with grey leather interior. I am looking to sell this vehicle because I am tired of putting money into it and I have a new car. Recently it has had a valve job, new rack and pinion, tie end rods/ tie rod ends (whatever they're called), new bushing for the gear selector, new water pump/timing belt (most recent repair), and new struts on all four wheels. Recently the car would not start and I do not want to fork over the money to the mechanic to fix it. It could be one of three things, the alternator, battery, or starter, but the car would not start with a jump so I'm guessing it's the alternator or starter. I live in Riverside California and you would have to find a way to transport the vehicle since is does not start. I'm asking 1,000 obo. The body is in good shape and the car looks good, my parents are the original owner of the car, then passed on to me, and it has been in the family since..let me know if ur interested. Oh and it has 225,000 miles.
i tried the vise grips but there isnt enought room for them to turn...and when it dosent turn it slides on the bolt....how else can i take dis bolt out i cant belive it takes this much to take out a damn fuel pump..
sorry just a lil pissed
There's a product out there made by the same people who make the real Vise Grips (Irwin is the company name, IIRC) for removing damaged or stripped bolts. It is a set of sockets that cut into the head of the bolt to grip it and remove it. It's similar to the sockets used to cut into and remove wheel locks if you lose the key. It costs around $25 for the set of 4-5 of sockets, I believe. We sell it at Pep Boys where I work, you could probably find it at a hardware store or Sears or something too. I've never tried them, but have heard they work really well. Might be worth checking out.
Good luck.
Good luck.
Try spraying the bolt with a good "rust spray" ...Liquid Wrench and let it sit overnight.....then what I have done with bolt heads that are rounded and can get with the VG.....get a small sharp metal chisle and hit the corners using a hammer.....and yes be careful not to create a spark...it is a gas tank..surround it with a damp rag.......Once it loosens...then maybe the Vice Grips can get it....
sctludwig
09-01-2022 01:32 PM
Maxima30
09-07-2015 06:13 PM
trungg86
09-04-2015 04:58 AM
