Wierd Cliclking noise?!?!?!?!
Old Sep 19, 2005 | 11:30 AM
Big_E-Dog's Avatar
2nd Gen Boostinator
well i was driving about a week ago and i now am hearing this wirerd repettive clicking noise. i popped the hood and it is deffinately internal, was just wondering what it was(but am hoping that it is not a valve slapping on the cylinder head) and the noise is rpm consistant it gets faster as the engine does. also a clicling noise in hard turns both axles were replaced so i not its not those.?? any help.....
my engine mods are:
300zx ecu
300zx MAF
short ram air iintake (like sarins)
and the 60 mm throttlebody mod with bored plentiun
Old Sep 19, 2005 | 12:23 PM
Niku-Sama's Avatar
a clicking in hard turns even after the axles have been replaced (why would you need to replace axles these are freakin tough as hell) suggest to me they werent packed with grease enough.
as for the ticking engine wise....exhaust leak?
Old Sep 19, 2005 | 12:42 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
hope not
it is a lil slower tho....
Old Sep 19, 2005 | 12:53 PM
SurraTT's Avatar
HR Swap Pioneer
power steering, i know u said internal but idk mabey
Old Sep 19, 2005 | 12:57 PM
maximase86's Avatar
I love lamp.
Bad C/V boot = replace half-shaft. It's cheaper and easier.
E: Can you pinpoint the ticking? I suggest some vacuum hose to use as a stephoscope (or however it's spelt). Just move it around the engine bay until you pinpoint it. How loud is this ticking? Also note you will notice ticking from the injectors....but they shouldn't be that loud.
S
Old Sep 19, 2005 | 01:52 PM
Niku-Sama's Avatar
inner or outer boot? i had an outer replaced for $50 and that was only done because i didnt have the tools at the time
Old Sep 19, 2005 | 03:22 PM
maximase86's Avatar
I love lamp.
My bad, I meant joint. Boots aren't too bad...but I'd usually buy a new halfshaft anyway since you can find half-shafts for cheap. By the time you have the boot off, you'd already have a new halfshaft installed.
S
Old Sep 20, 2005 | 01:00 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
but i already had both half shafts done could it be wheel bearings? Also the other clicking noise is on when the engine stands still and the sound is coming from the pass side top of the engine....
Old Sep 20, 2005 | 06:17 PM
maximase86's Avatar
I love lamp.
Nah, bad wheels bearing make a much worst noise than clicking. Can you redescribe the last part....I don't get it...
S
Old Sep 20, 2005 | 06:22 PM
SurraTT's Avatar
HR Swap Pioneer
mabey u has a spark plug wire that it cut and it is arcing,, ive had this happen b4 it was a pop click and it speed up at motor did
that will be so cool if im right , but i dout i am
Old Sep 22, 2005 | 08:36 PM
bluemaxima87's Avatar
Has the car been sitting? When I was working on my transmission I drained the oil out of my car because i was also working on my oil pan. When I finally got it back toghther I heard a clicking noise. It was the Valves clicking because it wasnt properly lubed yet. I put more oil in and it eventually got lubed up enough were it you couldnt hear the valves going up again. Just a suggestion.
Old Sep 25, 2005 | 02:23 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
might be the spark plug wired thats what i was expecting ill doubblecheck that.
Old Oct 8, 2005 | 10:09 AM
kiwikev's Avatar
could be tappets - check your valve clearances. also could be a broken valve spring or some fault in the valve train
Old Oct 8, 2005 | 02:47 PM
SurraTT's Avatar
HR Swap Pioneer
so im guessing it was something with ur t belt now??????? right? im really considring changing myne
Old Oct 12, 2005 | 01:01 PM
Helmuth48
Plug wires maybe ????....they do down hill quickly after 2 years in dry climate.... I had the same problem on another car and yes ....it was the a wire shorting out on the engine...it ran bad also......
Easy way to check it pop the hood in a dark area....raise the rpm and if you have a short ....you should be able to see it!!!!!
Use process of elimination....until you can narrow down the area...then do a deep dive!!!
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
