Possible F/S: Stanza TB
Jan 2, 2006 | 10:51 AM
If anyone is interested, you can just post here. I would take 25 shipped for it. My dad wants me to put the stock one back on the car. I will know for sure tomorrow evening.
Jan 3, 2006 | 06:03 AM
its off the car now
Jan 4, 2006 | 10:40 PM
this the one with the cruise control part on it?
i know some didnt have the other side of the throttl;e cable flangs for the cruise
Jan 5, 2006 | 06:22 AM
ummmm....its not like on my fourth gens, where two throttle cables are coming to the (throttle thingy, where it hooks). When this was on my car my cruise did work, with the second gen I don't think the TB has anything to do with cruise.
Jan 26, 2006 | 06:59 AM
does anyone want this beast?
Jan 26, 2006 | 07:23 AM
Why did you pull it off? Just curious (sorry to thread jack...)
Jan 26, 2006 | 07:37 AM
Quote: Why did you pull it off? Just curious (sorry to thread jack...)
Sold the car to my dad. He did not want a coolant bypass running on the car. Nothing is wrong with it, and my car ran just fine with it on. Do people use these on S12's? I had not thought about posting it there.
Jan 26, 2006 | 07:51 AM
I know they are used on the early model 240's I believe they had the vg30 in them. They are doing the same stuff we are doing over here with our second gens. Except more of them have the 300zx ecu mod.
Jan 26, 2006 | 06:41 PM
well i need a tb and this is 60mm right ? Im guessing this will fit for my 88 max , Is this hard to put on? and im guessing this works with the stock air box right? But i might just buy it and save it to put on when i buy a z ecu and maf , Doing the Real CIA. This will work right? Whats the stock on a max 50mm?
Jan 27, 2006 | 05:38 AM
Quote: well i need a tb and this is 60mm right ? Im guessing this will fit for my 88 max , Is this hard to put on? and im guessing this works with the stock air box right? But i might just buy it and save it to put on when i buy a z ecu and maf , Doing the Real CIA. This will work right? Whats the stock on a max 50mm?
Yeah man, its 60mm. Yes it will fit on your 88 max. Its a direct bolt on, it does not take any sort of adaptor plate. The only thing I had to change when I had this on the car were the coolant hoses running thru the TB. I just had to run a coolant bypass which is really no big deal. Let me know if you are interested or have more questions about it.
Jan 27, 2006 | 07:11 AM
Yeah ill buy it , If you could tell me how to do it , For my max .
Jan 27, 2006 | 07:26 AM
Quote: Yeah ill buy it , If you could tell me how to do it , For my max .
How to do what? Coolant bypass? Follow the line that is coming into the TB, and then the one coming out of the TB. See where they go into the engine and then run one line going from one to the other as opposed to the lines going thru the TB. My paypal is cardana24@yahoo.com
Jan 27, 2006 | 07:51 AM
I dont happen to have paypal , but will a money order be good? And what about the tb cable is that hard to take off? and put back on , Do i need any certen kinda tools?
Jan 27, 2006 | 07:55 AM
Quote: I dont happen to have paypal , but will a money order be good? And what about the tb cable is that hard to take off? and put back on , Do i need any certen kinda tools?
yeah a money order is fine. Check your PM, I'll email you my address, just let me know when to expect it. As for the throttle cable, its easy just turn it to WOT, and then it slides out....its obvious when you turn it to WOT. As for tools you will just need a socket wrench to take the TB off, and then a flate blade screw driver to take the intake tubing off the TB.
Jan 27, 2006 | 08:43 AM
ok , money will be sent out soon man , Ill pm you on the exact day i send it , Maybe be in a few after i get my taxes back.
Jan 27, 2006 | 04:53 PM
Carson, didn't you bore out the IM inlet to match the TB?
S
Jan 27, 2006 | 06:39 PM
yeah i came here just to ask , about that because i have no clue how to machine , So this is not even worth buying... for me atleast. But now if i could bore out the inlet , Or buy one already bored out then there you go id buy it.
Jan 29, 2006 | 10:57 AM
Quote: yeah i came here just to ask , about that because i have no clue how to machine , So this is not even worth buying... for me atleast. But now if i could bore out the inlet , Or buy one already bored out then there you go id buy it.
It's easy. All I used was a sanding flapper wheel. You can get them at Sears. Just put it on the end of your drill and it will do all the work. Just mark the plenum with a marker and sand until you hit that point. It took me about 20 minutes. Just remember to stick a rag in there before you start going to town, so you will not suck all the shavings in when you start the car back up.
Jan 29, 2006 | 12:13 PM
alright ill buy it , thanks for the info , after all its worth it ill send it in the next couple days.
Jan 29, 2006 | 12:36 PM
argh
10char
Jan 29, 2006 | 01:17 PM
huh? what do you mean argh 10 char?
Jan 30, 2006 | 05:20 AM
Quote: alright ill buy it , thanks for the info , after all its worth it ill send it in the next couple days.
sounds good. Just let me know when the M/O goes out
Jan 30, 2006 | 06:14 AM
I think Niku might have wanted it. DJ the good thing about this, is you got a good performance mod. More air into the intake means abit more power and throttle response. Congrats on the new buy.
Jan 30, 2006 | 06:39 AM
Yep , Thats why i was gonna buy it , But i forgot i had to bore out the IM Entrance , Because i recently had my house broken into and about all my tools stolen , I could not complete this but my grandfather should have a drill so now i could compelete this , Once i recive i shall leave pos seller feedback.
