bent valve??
bent valve??
well eversence i done my timmbing belt ihe had a ticking from the rear head, right above the broke exhaust stud leak, but it wasent to bad
untill the other day i put in about a whole can of seafoam, then now in the morning and when its coold off any, i get this bad ticking from the same spot it def goes with rpm and sound like a valve hitting something. but within a min or 2 its gone
i just changed the oil hoping it would fix it but no good
i think its the valve is best a lil and when its cold the head is closer to the piston and it barley hits, but when its hot it expands up and has more distsnce
or the seafoam ruined something on my valve
whats yall think????????
If it goes away when it warms up, it's almost definately lifter tick. Not a big deal it can just be annoying. The only way to completely fix it is to replace the lifters, but I find that a a slightly thicker oil helps some. My Z has had the same problem for two years now, and it hasn't had a negative affect yet.
Tick Tick Tick
You said that you have a broken exhaust stud right where the ticking is coming from. Then you say in a couple of minutes it goes away. I have had this happen to me before. The tick would go away when the manifold gets hot because the heat makes the manifold and head expand. I fixed the the stud and the sound whent away.
SEE NO Z
![doublethumbsup](https://maxima.org/forums/images/smilies/dblthumb2.gif)
SEE NO Z
i just dont understand why seafoam would make it start......
and i noticed my gas mileage is FING horrible i got about 125 miles to a tank, that just started this week
im trying to get that nice 92 i seen around here, i know myne prob isent going to last through the summer
Seafoam can knock a lot of crud loose, and in a motor as old as yours, that isn't always a good idea as that crud can hold a lot of things together, ie gaskets.
Lifter tick after a seafoam treatment is not uncommon. But lifter tick isn't necessarily a bad thing. It will come and go based on the temp of the motor and whether or not air is caught in the lifter, which happens often. Don't worry about it.
It is also a good idea to inspect your plugs following a seafoam treatment.
TKHanson
11-24-2018 01:39 AM
tseng1023
10-15-2015 08:30 AM
hayne
10-05-2015 11:53 AM
DC_Juggernaut
09-28-2015 04:07 PM
