How to remove right side half shaft??
I never changed the right side on my second gen, but if its like every other right side fwd axle then it sould come out similar to the left side. There should be a mounting bracket holding it to the block. After you take that off you should be able to pull it out. If you can not pull it out then you will need to pry on it. I usually use a pickle fork to pry mine.
The Frye
Sep 2, 2021 11:03 AM
boomerbrian
Oct 31, 2018 10:25 AM
lowpost99
Sep 8, 2015 05:06 AM
