Bigger brakes on 1st gen?
Old Apr 5, 2006 | 11:27 PM
seenoz's Avatar
Has any one put bigger brakes on a 1st gen? I have a 82 Max and would like to put some more stopping power on it. May be a five lug swap at the same time?
SEE NO Z
Old Apr 5, 2006 | 11:49 PM
Jeff92se's Avatar
I'm needing a caw
I'm sure there must be. You are basicly driving a 4 door Z. Maybe look into one of the Z31 series 300z. Or the Q45/J30 with their 2 piston calipers. You might have to move up in wheels size. And maybe install a larger master cylinder. But it should be an easy bolt for all parts.
Old Apr 6, 2006 | 08:15 PM
seenoz's Avatar
Stop that Maxima.
I did use 1st gen bakes,rotors and struts on my Datsun 510 wagon. It stops REEEAL GOOD. I was thinking of 300Z parts also. The 1st gens have a front wheel drive offset. I need to go to pick 'N' pull and do some test fitting.
Thanks for the tips.
SEE NO Z
Old May 2, 2006 | 11:36 AM
sixty8panther's Avatar
If I ever do a trubo setup on my '84 I will probably need
more stopping power too. The Maxima has good solid
brakes but just like HP, you can never have too much.
Matt93SE
May 24, 2019 02:58 PM
03VQMAX
Sep 25, 2015 04:19 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
Lowered_a33
Aug 24, 2015 04:35 AM
criminalslang810
Aug 16, 2015 08:12 AM
