So... im gettin her runnin for winter again
Old Oct 21, 2006 | 09:17 AM
Kman87's Avatar
as it says, i'm fixin her up for winter driving this year. It still has the usual problems with the starter and bad gas mileage.
how much does is it gonna cost to have the flywheel replaced? and should i go ahead and have the timing belt replaced too?
if i change the fuel filter and little tune up things do you think my gas mileage will improve or do i have to go deeper than that?
thanks
Old Oct 21, 2006 | 09:29 AM
Yayomax's Avatar
still brewin'
thanks
1) Whats the usual problem with the starter? How is your gas mileage?
2)What's up with flywheel; how many miles on the timing belt?
3)It's a good idea to change the fuel filter, and primarily the air filter if you still have the filter box.
Old Oct 21, 2006 | 09:42 AM
VGsidestepper
Can a bad CHTS cause bad gas mileage and decreased performance?
Old Oct 21, 2006 | 10:27 AM
Kman87's Avatar
the teeth on my flywheel are bad so its hard to get the starters teeth to mesh with the flywheel. so it grinds and grinds til it gets a good mesh. I have 155k on the engine and I havent changed the belt since i have had it at 112k. The gas mileage averages 18-20mpg
Old Oct 22, 2006 | 09:25 PM
Niku-Sama's Avatar
heck yea man, change that *****!
as for the timing belt, mine wasnt ever changed when i bought the car, i had made an appointment to get it changed and then teeth came off the belt it was so old and decayed. it was also at about 155,000 miles
the appointment was less than a week away
aw11power
Oct 10, 2021 04:57 AM
mclasser
22
Nov 12, 2020 01:58 PM
240tomax
Tires and Wheels
Feb 10, 2016 11:01 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
