looking for a .bin file for my ecu
Old Jan 29, 2007 | 01:19 PM
Mr. Blue Sky's Avatar
I would like to know if anyone here has a z31 NA tune or the stock bin file from an automatic 1986 z31 ecu? I would like to have one so I can do an easy tune(that is if my consult works) from my maximas stock tune to the z31 NA automatic transmission stock tune. I don't want the hassles of switching ECUs and making sure the wiring harness connector fits, etc.
Old Jan 29, 2007 | 05:16 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
itl fit if you get your year complete swap
Old Feb 3, 2007 | 05:00 PM
neo_densetsu's Avatar
I've been trying to get one too. I can get Turbo Z31 88 bins, but no NA bins. Im trying to get an EPROM burner to make custom tunes, I can probably make a modded tune for the Z31 N/A ECU.
I dont think you can flash it with the consult, Im not sure if there is a Consult port on the 2nd gens.
What does the inside of your ECU look? Do you have a 28 pin EPROM? If so, you can get an upgraded rom chip installed.
Too bad I no longer have an N/A 2nd Gen, or else I would make a custom tune at my school with their dyno. Im making a tune for my turbo setup, once i get it completed.
Also, you'd probably have to swap your MAFS, if you switched ECU's, cause the Z31 MAFS are different from the Max's MAFS, the ECU programed for the specific ECU's. But if you were able to get a modded Z31 N/A tune, you could program it for the Max's MAFS.
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
QueensMAX
Sep 15, 2015 04:14 AM
