87 problems..
Old Sep 22, 2001 | 11:01 PM
Permagrin
87 problems..
I recently inherited an 87 GXE with about 140k on it.
Ok, here is the main problem, it totally gutless and eats gas like a humvee.. The AC kills the power even more. I changed the plugs, no help there. I did a carfax report on it and there were no problems other than it failed a smog once (I'm in Socal). I'm pretty sure that the lousy mileage is related the poor power. I'm pretty sure that a v-6 should be quicker of the line.. So, what should I bee looking into? Fuel injectors? would putting in a can if FI cleaner help at all? Also, would a timing belt change show up in a carfax report? I read on another post that there was a recall on the FIs Can a dealer find out if my car was fixed? I have a lot more questiosn.. I'll just stick to these for now..
PermaGrin
Old Sep 23, 2001 | 07:27 AM
Charles Bisel
You can call up the dealer and give him your VIN and he can check and see if the fuel injector recall was performed. I still have to get mine done, but I don't believe it has robbed me of power or fuel econonmy. The interior of the car just smells like gas once in a while.
As for your problem, I'd start by checking the computer, it's located under the passenger seat. You'll need a Haynes or Chilton manual to be able to read the codes. Usually a bad sensor can result in poor mileage and power. If that's all good, then you might just need a tune up.
Old Sep 27, 2001 | 07:47 PM
LucentAUTO's Avatar
dont call the nissan dealer, just goto pep boys, alot cheaper.
Old Sep 28, 2001 | 04:35 AM
Charles Bisel
The recall is free.
a33_ridah
Jul 14, 2015 11:53 PM
Yoshimitsu
Jan 27, 2013 03:23 PM
watkins2010
Jun 20, 2012 09:42 PM
LucKie1nE
Sep 2, 2011 09:31 AM
Compton
Feb 16, 2002 07:35 PM
