clicking sound
Old Nov 6, 2000 | 10:27 AM
youthmin26
'88 Maxima SE- At very low speeds, say, less than 20 mph, I hear a clicking sound from the right rear tire area. Any ideas what this might be?
Old Nov 6, 2000 | 11:42 AM
DDD
Me too (3rd Gen. 5 sp)
The clicking is "soft" and not loud. But if to try thoroughly I can hear the sound, say up to 30 mph (less loud, higher tone). At speeds less than 5 mph the clicking is synchronous with the wheel(s) revolutions. Also it doesn't matter if I'm cornering or drive straight. On the short humps and holes (and 5 to 10 seconds after) the sound is more noticeable.
Ideas - ball bearings or the "internal" CVJ, but I'm not sure.
Pls drop some lines on the Forum upon fixing.
Regards,
DDD
Old Nov 6, 2000 | 02:20 PM
max95q's Avatar
ok I had that problem at low speeds and you know what it was
a bolt was off of my wheel and rolling around in my wheel cap. aND it only happened at low speeds so check that .
Old Nov 7, 2000 | 11:16 AM
DDD
Bolts are OK regretfully
Thank you Max88q
It might be something more serious.
By the way, sometimes the clicking happens just after shifting to neutral. Also, I remember that once I found a loose bar (something around 1.5 to 2 ft long) running from the gear box to somewhere on the bottom of the body.
Maybe it's a culprit.
Regards,
DDD
P.S. I've noticed there only few of 1\2 Gen owners on the Forum. Do you visit 3 Gen. forum? Your car is very similar to the 3Gens, so you'll find a lot of useful info there.
Old Nov 7, 2000 | 07:20 PM
max95q's Avatar
yeh i go in the 3rd gen forum
Im the only reall really active 2nd gen max owner in the forum. But its all good . Its good to be different
Old Nov 13, 2000 | 12:37 PM
youthmin26
Re: ok I had that problem at low speeds and you know what it was
Good call on that one. One of my lug nuts was off and rolling around. Tightened her up and no clicking sound. Thanks, I never would have thought of that. Later
Old Nov 21, 2000 | 11:03 AM
CLIFF
clicking..
had the same problem...turned out to be rear brake pad shims were not replaced with the new pads...these are antirattle shims...if they are cracked of missing, the brake pads wil 'drag' on the rotor and move back and forth in the caliper, causing the 'clicking' noise (it sounds like a bad bearing, very frustrating)
Old Nov 24, 2000 | 02:58 PM
xhytnrunx
Strut Bars
Hey dooods....do any of yall know if they make any strut bars for the 87' model....and another thing.....i hear a clickin sound in my car...everytime i turn the steering wheel....so what up wit taht.....could it be the cv boot?? Well let me know what up...laters
Old Nov 24, 2000 | 09:36 PM
max95q's Avatar
yes the clicking when ou turn is the cv boot
Sorry to let you know my friend but its the cv joints. Your boot is cracked and dirt particles have gotten in side and its grinding the joints. Need to get that replaced pronto. Sorry they dont make tower strut bars for our cars. there isnt enough demand for them. The only way is to custom make one or custom fit on from another car on to ours and make custom ends .
Mahmuth
Aug 16, 2024 08:23 PM
jmlee44
Oct 2, 2022 02:13 PM
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
mclasser
Sep 24, 2015 11:57 PM
