1st gen L28 swap thread!
Old Mar 10, 2011 | 02:52 PM
High5maxi!'s Avatar
I hit the rear panel in my Z so ive decided to take all the goodies for my maxi! :]
durrrty
cleaned up a bit
More to come as i get it done....
Old Mar 18, 2011 | 07:29 PM
High5maxi!'s Avatar
Had the oil pickup flipped and tweeked by local welding shop. the oil pan is now on but i broke one of the oil pan bolts =/ im hoping it wont leak horribly till i get it fixed
Old Mar 18, 2011 | 07:35 PM
chrome91's Avatar
looks good
Old Mar 18, 2011 | 09:28 PM
High5maxi!'s Avatar
Thanks, ive been searching all around beforehand to find a pic of someones oil pickup modded for the front sump but couldnt find nada... now someone in the future can find this thread and see it..
you think that one broke oil pan bolt is gonna be a severe problem?
Old Mar 18, 2011 | 09:56 PM
chrome91's Avatar
i remember one guy with another car had one broke bolt (Corolla i believe) and didnt have any problems IIRC, wouldnt leave it like that for a while though
Old Mar 18, 2011 | 10:12 PM
High5maxi!'s Avatar
ahh okay i hope the same goes for mine. i am gonna get it fixed i just want to have my car running so i can drive it somewhere to get it done. thankfully its in a place where i can get to it with the motor in the car easily
Old Mar 22, 2011 | 09:14 AM
High5maxi!'s Avatar
L28 is now in the car. still need to finish hooking up the wiring, vacuum lines then the tranny, driveshaft, and exhaust
Old Apr 3, 2011 | 03:33 PM
High5maxi!'s Avatar
How my maxi is currently
put the tranny in and driveshaft on. used the mounts from the automatic, they dont exactly bolt up but thats somthing ill fix soon.
Old Apr 4, 2011 | 12:45 PM
High5maxi!'s Avatar
Old Apr 12, 2011 | 08:40 AM
HowlerMonkey's Avatar
That shifter boot rules!!
Old Apr 14, 2011 | 05:16 PM
High5maxi!'s Avatar
cut/re-wired harness's together. fuel is good and its cranking over but the coil isnt getting spark yet.
Old Apr 16, 2011 | 02:27 PM
High5maxi!'s Avatar
now running but making a not so good noise..
Old Apr 18, 2011 | 07:26 PM
turkeypantz's Avatar
why do you modify the oil sump?
will I have to do that for my 77 280z engine into my 84 max?
where did you mod the wiring harness?
I was planning on using the entire 77 280z engine harness to the 77 280z ECU.
Then mod the dash (gauges) wiring as needed.
Is there something I'm not fore seeing?
Old Apr 18, 2011 | 10:43 PM
High5maxi!'s Avatar
the maxima uses a front sump oil pan while Z cars had rear sump so in order for it to clear you either need to mod your oil pickup like i did or take the engine to a machine shop and have them tap/drill the holes for the front sump oil pickup and block off the other one. if your gonna go and get it machined do a bit more research cause they need to watch for an oil passage way or somthing when relocating the oil dipstick
you can either use your stock harness, cut it at the ECU plug and wire in the 280z one or you can use the complete harness like i did and wire it in where the stock engine harness plugs into the body harness. first one might be alot easier though
my maxi runs ok now. i didnt have any problem with the guages besides my temp and oil pressure. gotta look into that tomorrow
Old Apr 19, 2011 | 12:28 AM
thanks for the info!
I think I may take your advice on only changing the ECU harness.
And I guess I have to get my oil sump modified.
You said you had your sump flipped and tweaked.
What was the "tweaked" part? Its not just a mirror image of the original sump position?
TRANSMISSION MOUNT: After looking at your picture of original transmission mount-bracket missing the 4th hole on the body, I envision an easy fix. Using a flat piece of 3/8 (or 1/4) steel thats 2" wide and long enough to reach the 2 holes on the body and the 2 hole on the bracket. Sandwich it between the mount-bracket and the body side holes. The adaptor will have 3 holes, as the 1 middle hole will line up to the bracket and body mounting hole. I would use the same material to shim the other side of the bracket, to keep it level. You could weld it to the bracket, but I don't think its necessary.
Old Apr 19, 2011 | 08:24 AM
High5maxi!'s Avatar
nah you dont have to do anything to the sump itself. youd have to take the oil pickup and have it rotated so it goes where the front sump oil pickup would go. once you get the two engines out and take the oil pans off it will be more clear what youll have to do.
yeah thats what i was thinking too. i just dont have the materials or tools to do that in my garage right now lol
Old Jun 29, 2011 | 05:23 PM
High5maxi!'s Avatar
little driftin video
http://youtu.be/h89MlvVtT6g
Old Jun 30, 2011 | 09:53 PM
CMax03's Avatar
I surely love those L-Series (4 & 6 cyl) Nissan engines
Old Jun 30, 2011 | 09:59 PM
CMax03's Avatar
HP books has a nice book I Highly recommended.... "How to Modify Your Nissan/Datsun OHC Engine"....Nissan Part Number 99996-M8012, by Frank Honsowetz (Hp book 537) and maybe pic up a Nissan Motorsport Catalog from Courtesy Nissan....has all the right Factory parts to build a reliable monster!
Old Jul 1, 2011 | 11:07 AM
aackshun's Avatar
The CMax03 has spoken.
Old Jul 1, 2011 | 10:31 PM
CMax03's Avatar
I would install a high capacity 280zx Turbo oil pump while you're at it!
Old Jul 31, 2011 | 09:33 PM
L28 into my 84 maxima
I ended up drilling the block, to mount the maxima's oil pick up. I felt better about the fitment (and I don't weld). I used a small magnet to remove the shavings. Flushing with brake cleaner doesn't do much.
Tomorrow I will run the hydraulic line, for the clutch. Then I will be installing the engine and manual trans. It better not rain!
Matt93SE
May 24, 2019 02:58 PM
Fakie J Farkerton
Oct 14, 2015 06:25 PM
Finkle
Sep 27, 2015 09:53 PM
criminalslang810
Aug 16, 2015 08:12 AM
Blackwind
Aug 5, 2015 06:35 PM
