1st gen spuddering and shooting off black smoke
Old Dec 28, 2012 | 07:04 PM
Christopher Sides's Avatar
I just did my front suspension and my car is now spuddering and not getting power and i know i didn't mess up my fuel lines or ignition wires or anything related what could be giving me issues? any people had this happen? any info would be nice so i can look for other issues that might be the cause. thanks for anyone who tries to help me. also the car was angled in the air for like 4 hours during repair if that helps.
Old Dec 28, 2012 | 08:20 PM
vernk's Avatar
black smoke = flooding out, make sure the intake is clear, make sure wires going to the injectors are good, irrc the injectors are neg controlled, so if the ground wire for the injector is shorted the injector will stay open flooding it, other then that check the ohms of the injectors to make sure they are good.... one other thought check the wiring harness to see if it runs near where the jack was put....
Old Dec 29, 2012 | 06:00 AM
Thanks man I will get on it tomorrow its rainy and cold today. After 2 days of suspension work and a ball joint that wouldn't come out this happened. Talk about rotten luck.
Old Dec 30, 2012 | 04:33 PM
So I found out my cold start valve is leaking and shooting fuel upwards. I can't find the part any where, anyone happen to know a place that will sell me one? also would this cause my car to run that bad?
Old Dec 30, 2012 | 09:29 PM
chrome91's Avatar
if its causing too much fuel to be dumped in constantly, that'll do it. i wouldnt drive to vehicle until you get it fixed, if you run it that rich for too long you can foul the cat converter and 02 sensors
if you cant get the part new, try to get a used one from Z. youve got a L28E engine right? should be able to get one from a 280Z/ZX
Old Jan 1, 2013 | 01:40 PM
Good news everyone! I found a cold start valve it should be here sometime thanks for all the help!
Matt93SE
May 24, 2019 02:58 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
criminalslang810
Aug 16, 2015 08:12 AM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
