Help - 1987 Maxima Ignition / digital dash issues
Old Nov 19, 2013 | 12:52 PM
sootie's Avatar
I've been having intermittent issues with the speedometer registering zero. When this happens, the odometer and cruise control do not work.
Recently the ignition switch has failed will not spring back from start. Today when I started the car the entire dash was dark. I restarted the the car and the dash came back to life.
Is the speedometer issue related to the ignition problem? I've ordered a new ignition switch which includes the bracket, switch and cylinder lock.
Does anyone know the steps for removing the old bracket from the steering column? Do I have to drill out the security bolts to remove the old switch?
Any help and/or pictures would be appreciated!
Old May 30, 2014 | 12:27 PM
FanaticMadMax's Avatar
the ignition swtich is the culprit which usually powers up your cars from the dash to window switches as for the key to spring back, sound like bad tumbler, so you would have to to disassemble it and see what the problem could be. I am not sure if there are security bolts on them, if they do, yes they have to be drilled out but I would check the availability of the part before taking on taking apart on your steering column so you know what you are getting into
Old May 31, 2014 | 02:04 PM
CMax03's Avatar
I just replaced a 98's ignition switch cylinder lock....I think it's was easier to diegrind the security bolts off than drilling the heads off....If you have a 90 degree drill it's easier! I initially tried using a small 1/4" air drill and it was still to long to get straight on the bolts...So I diegrinded the heads down tothe shanks and knocked it off!!! Felt like I was a car thief there for a few minutes! I purchase mine thru Rockauto...Good Luck man!
scutmud
Aug 16, 2018 10:56 AM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
criminalslang810
Aug 9, 2015 03:35 PM
dauntlessmax
Aug 5, 2015 10:29 AM
maxima297
Aug 3, 2015 12:50 PM
