HELP 1987 5sp tranny swap questions
Old Oct 1, 2015 | 05:07 AM
fx4five's Avatar
Hello everyone, I have a great condition 87 maxima se, 5 sp, and my tranny is destroyed, I need help finding one or figuring put what other years will work. Maybe 91ish, don't know. Thanks
Old Oct 1, 2015 | 05:37 PM
vernk's Avatar
85-91 maxima will work 92-94 might but they are VE engines and have different axles irrc, if it's a VG 5sp it will work
Old Oct 1, 2015 | 05:40 PM
vernk's Avatar
although you might be better off rebuilding it last time I priced out the bearings I think it came to around $200 if you can take it apart yourself it shouldn't be to much to have a shop press them....
Old Oct 2, 2015 | 06:32 PM
aw11power's Avatar
rebuilding isnt a terrible option. I just rebuilt mine about 6 months ago. full bearing and seal set cost me $300(in texas). as a side tech note, transmissions in VE cars WILL NOT work. bell housing and starter location is completely different. 89+ VG cars have the same part number as our 2nd gen transmission and will work, but have a lower final drive gear ratio. I learned that the hard way. 2nd gen final drive is 3.428 for auto and 3.429 for 5 speed. 3rd gen 5 speed is 3.650. I have a 91 trans in my 88. had to go up to 3rd gen tire size (205/65/15) to correct speedometer and get mpgs somewhat back in check.
Old Oct 2, 2015 | 06:34 PM
aw11power's Avatar
and FWIW, the mpgs still suck lol!
Old Oct 4, 2015 | 08:11 AM
lowpost99's Avatar
Resources to help with transmissions
Where can I get my hands on some transmission documentation? I was need to diagnose what's wrong with.mine..annoying problems..
Old Oct 4, 2015 | 06:30 PM
aw11power's Avatar
i could get you some documentation, but is really not as helpful as just asking someone that knows anything about manuals. what is yours doing? i can tell you whats wrong with it.
fwiw, any issue you have is gonna require at least pulling and opening the trans...
Old Oct 6, 2015 | 11:48 AM
lowpost99's Avatar
I have an 88 auto, using moblie 1 syn atf for about 2 years since I had it rebuilt.
In the morning when the car has not been driven, 1st and maybe 2nd gear are really hard to shift up, it takes me about a mile or so for each shift, so I drive really easy on the motor, cause otherwise, it just slips a bit and revs the engine excessively. Feels like I'm dragging something or the parking brake applied, After I get 2nd or 3rd, boom! every thing begins to smooths just fine out for the remainder of the day, but the issue repeats every day.
Old Oct 18, 2015 | 06:57 PM
aw11power's Avatar
youre, losing pressure from the internal piston seals being worn out. once the trans is warm the parts expand and it begins to work normally. needs to be rebuilt. i had the same problem with mine. I switch to 5 speed as a result. had a hard time finding parts to repair the auto and prefer a manual anyway. sorry for the late responce.
pktaske
May 6, 2016 07:49 AM
I<3 A32's
Sep 10, 2015 11:07 AM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
Lowered_a33
Sep 1, 2015 07:49 PM
