Need a lil insight to an electrical issue 84 maxima
Old Sep 26, 2019 | 04:38 PM
Jason Gomez's Avatar
Hoping someone out there will have had this experience or at least some insight into the issue. First off let me start with I have pulled all the fuses and they are good, and the Bat1 Bat2 and accessory and ignition sections of the fuse panel are getting current where applicable. Ok so now that is out of the way. Swapped out my battery for a new one, since then I no longer have the voice warning system(although when you press the repeat button you can hear the motor spinning), no digital clock, stock radio wont save presets and reverts back to am once car is shut off. Also digital speedo stays at 0 but not sure if that is related. Thank you in advance.
Old Sep 26, 2019 | 08:12 PM
chrome91's Avatar
you didnt hook up the battery backwards at first correct? if you did, theres a possibility you fried something electrical. you try swapping around relays?
Jeff S
Dec 1, 2016 07:43 PM
PasswordIsTaco
Jun 18, 2013 08:53 AM
FenderGuy
Apr 9, 2013 12:29 AM
playtoy
Jun 25, 2012 08:23 PM
clive
Jul 20, 2008 04:00 PM
