Water Leak in Trunk
Old Mar 24, 2022 | 12:22 PM
Edge's Avatar
Water Leak in Trunk
I have a water leak coming in from under the right trunk hinge. I have cleared the sunroof drains and both the rear window seal and antenna seal good. Are sunroof drain hoses are leaking an possible cause?Trunk seal and rear tail light are not the problem since water is coming inside near where the hinge is located. Any other places to check?
Old May 26, 2022 | 08:14 PM
FanaticMadMax's Avatar
check under the driver rear behind the wheel there's a drain, they usually get clogged, that happened to me when I was looking in the trunk in the little cubby hole there was a puddle of water turned out the tube that expel down there was clogged with a lot of dirt. so that resolved the problem by sticking a stick poking in in the tube and the water gushing out and muddy.
matts95max
Dec 17, 2013 08:56 PM
jvc1986
Sep 20, 2009 04:48 AM
cmuehlenb
Jan 6, 2005 07:38 AM
kodysmax
Jun 25, 2002 12:16 PM
matty
Apr 1, 2001 09:11 PM
