1987 Maxima timing belt question
Old Mar 30, 2002 | 12:41 PM
dml000's Avatar
My car just died one day and I figured out it was the timing belt.
What are the odds that it did engine damage.
Old Mar 30, 2002 | 11:52 PM
Nismo87SE's Avatar
95% that it damaged the engine. My uncle's belt broke but his car was under 2000rpm with basically no load. All he did was get a new belt installed. Right now all you can do is install a new belt and do a compression test as outlined in the haynes/chilton repair manual. If it comes out bad, then you have to either get another set of heads or get another engine.
Old Apr 6, 2002 | 07:26 PM
siclmn's Avatar
Re: 1987 Maxima timing belt question
I lucked out because my belt broke at 60 mph and I just took a chance and put a new one on myself and turned the key and it was just fine. But they say that I was lucky.
Old Apr 6, 2002 | 08:49 PM
alllw86's Avatar
Re: Re: 1987 Maxima timing belt question
You sure are lucky not to have any damage done. Does your car have an automatic?
My friend had an 85 Accord w/auto, belt broke rounding an off-ramp, replaced it and no damage.
My 86SE with 5sp was not so lucky, rounding an on-ramp at 25mph, lost power and I knew what had happened, pop the clutch-in hoping it was not too late. Two exhaust valves were bend, but I went ahead and changed them all.
Just curious, AL
ah2002
Mar 9, 2016 01:42 PM
Ray229Harris
Sep 16, 2015 08:16 PM
criminalslang810
Aug 9, 2015 03:35 PM
ZerotoSixty
Aug 6, 2015 04:34 AM
