Engine Shaking and Miss Firing?
Old Jul 12, 2002 | 10:34 PM
godspeed's Avatar
Hoping to get some info from all you knowledged guys out there on this one. As this forum is my last hope.
Anyway I got a auto SE 1992.
Engine seems to be miss firing or something, cause you can feel it periodical shaking on the steering wheel? like every 1/2 second. Also around 1500 to 1900 rpm, if you hold it there you can really feel the engine shake widly, but once over 2000rpm it disappears?
Now is this a timing problem? I am thinking it might be the leads or the distrubitor which isnt doing its job right, therefore causing miss firing for one of the cylinders.
I changed injectors few months ago and also changed the timing belt (altough it was home job).
When I first bought the car, it was running on 5 cylinders and the timing was right off, drove it like that for a while, maybe the whole drive line is stuffed as result.
I just cant get the car to run the way I want it to . Really thinking of selling it and making a very large loan to get my R32 GTR..hahahha
Old Jul 12, 2002 | 10:45 PM
Nismo87SE's Avatar
Re: Engine Shaking and Miss Firing?
Try unplugging each injector to see if a cylinder isn't firing 100%. Now if you find out all cylinders are operating the same, then you pull the codes from the ECU if there are any. If you haven't now go buy a haynes manual at least or get a nissan FSM.
Old Jul 12, 2002 | 10:53 PM
godspeed's Avatar
I actually got the origianl two volume nissan manual.
After I bought the car , and like I said it was running on 5 cylinders, although, it was well hidden as somone advance the timing so much you could hardly tell. Anyway it was a nightmare to ge the car running on 6 again, changed one bad injector and then another one failed so then changed all the rest.
I also at that time did a diognostic check following the manual and the codes tells me everything is fine. Although maybe I should do one again.
conansriver
Nov 18, 2015 02:46 PM
RinconI30
Nov 10, 2015 10:55 PM
ballerchris510
Sep 11, 2015 05:29 PM
A32goldylocks
Sep 2, 2015 06:39 AM
