has anyone mounted a speaker here......
Old Dec 12, 2000 | 05:49 PM
93 SE's Avatar
i got 2 extra speakers and i was thinkin about mounting them on the cardboard on the back armrest...6 1/2s has anyone done it
Old Dec 12, 2000 | 06:29 PM
John van de Pol's Avatar
cardboard panel
I wouldn't as is. The panel is weak and not well attached. Between the speaker vibration and the motions of the car, I think the speakers will tear loose.
However, if you really want to use the location, use the cardboard as a template, and make a new one out of 3/4 inch plywood or MDF. You will have the "meat" to mount the speakers, the meat to mount the panel properly, and it won't vibrate to pieces.
If it does not work out to your liking you can replace the original panel intact, and write the whole experiment off to experience.
Good luck,
John
Old Dec 12, 2000 | 07:11 PM
amax935's Avatar
I wouldn't
IMHO even if you could get it mounted tight, it wouldn't have enough space to process lows, and it would probably just cloud the soundstage.
Old Dec 12, 2000 | 10:14 PM
Brandon90gxe's Avatar
what brand of 6.5? hey you dont need em, wanna sell em, if theyre good? how much you want?
Old Dec 12, 2000 | 10:24 PM
93 SE's Avatar
its jbl...i think there $25 at circutcity...i got it free when i bought the radio...its just a normal basic speaker ill probably use for backup
Old Dec 12, 2000 | 10:27 PM
chris92gxe's Avatar
I was thinking about mounting a pair of 6.5 in the rear door panels. You could easily customoze it to look like the ones in the front. A lot of new cars use a 6 speaker system and I think that it would look and sound good. Just an idea.
Old Dec 13, 2000 | 11:15 AM
Greyboy
I took my door apart not too long ago to see why the light wasn't working. I really don't think there's enough clearance behind that and the window inside the door to put speakers in there. You could try though.
Old Dec 13, 2000 | 11:52 AM
Foo90SE
hmm seems like maybe there would be enough room in the back door, cuz those windows only go down half way. But iv never had the door panel apart so i duno.
Old Dec 13, 2000 | 02:19 PM
Chris Gregg's Avatar
Get Off My Lawn
I've had the back door panels off and you're right, the window does only go down half way. I think you can do it. I thought about it myself but never did cause my stereo is loud enough even with the subs off! But, to be safe, take the door panel off, the windor will have to be down to get it off easier anyway. Then, just look to see, measure the speaker your using and use your best judgement. I think you'll have to buy one of those foam speaker backings though. You know what I'm talking about? It's like an enclosure for the back of the speaker to protect it from the wheather.
Unclejunebug
Apr 2, 2016 05:42 AM
magiconthetire
Oct 26, 2015 09:03 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
sliptap
Sep 30, 2015 05:57 AM
