Sounds Like Double-Sided Tape Stuck To Tires????
Old Aug 3, 2002 | 12:09 AM
Kenny's89SE's Avatar
anyone know what i could possibly be talking about....its coming from the front right tire area. I've done the obvious (check the tire for double sided tape , but there was none there so i give up...it also sounds kinda like belts rubbing against something..ill check that when the sun comes up. (didnt have a flashlight) anyone ever have this problem? As of now there is no side effects besides the sound but if it is a problem i would like to get it done before it turns into something nasty....thanks for any help. (1989 Se)
Old Aug 3, 2002 | 07:33 AM
Cincy94Max's Avatar
Maybe you flat spotted one of your tires or have a flat? Check the tire pressure and the tread length of your tires all the way around the tire. I flat spotted two of my tires a while back and it's like driving a flintstone mobile with stone tires: bump bump bump bump bump thump thump thump thump.
Old Aug 4, 2002 | 06:30 PM
after daylight came i looked down and my plastic wheel well had broke around the bolt and rubbed on my tire and finally ripped a piece off..now i have kindof a worn down spot on the inside of my front right tire.
Mar 12, 2020 12:06 AM
RWCreative
Sep 21, 2015 11:01 AM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
jfl330
Sep 4, 2015 01:44 PM
A32goldylocks
Sep 2, 2015 06:39 AM
