y pipe problem
Old Aug 8, 2002 | 06:32 PM
simplerx's Avatar
y pipe problem
I just got a wsp y pipe and hi flow cat installed, and when i leave the car running but not accelerating the car starts to vibrate a little and it makes a loose clamp noise, but the mechanic said all the clamps are secure. I know other ppl with y pipes had this problem so any1 tell me how they fixed it?
tnx
Old Aug 8, 2002 | 06:47 PM
MaximaJohnny's Avatar
If oyu know other people pon the forum has problems with it then why dont u search for their thread and read how they fixed it?
Old Aug 8, 2002 | 06:50 PM
simplerx's Avatar
In other words you don't know
And what makes u think i didn't search
Old Aug 8, 2002 | 06:56 PM
James12345's Avatar
Re: y pipe problem
tnx
A loose clamp noise?
What clamps are there? It's jut pretty much a straight bolt on...there shouldnt be any 'clamps'.
A better description would do wonders.
Old Aug 8, 2002 | 07:45 PM
male's Avatar
Re: Re: y pipe problem
You might call the cat to y-pipe flange a "clamp"..at least if you have a wsp pipe.. Nomenclature that's all. You can still use your imagination to figure out what he means. Check your y-pipe to front sway bar clearance..sometimes they hit. Honestly, the best way to finc out what it is is to get your car to the nearest pepe boys, throw the tech some cash to look it over and get under there with him. Poke around and see what you can find..might be a heat shield or something like that. I yanked all my shields..nothing but problems once you modify a system.
Old Aug 8, 2002 | 08:40 PM
simplerx's Avatar
I should go to the mechanic that did it but since its an aftermarket hell probably charge me to fix it, its like a metal rattling sound, and it gets better i think when the car gets warmed up, but thats probably me just me being optimistic
Called up wps said theyll call me back
Old Aug 9, 2002 | 01:26 AM
mykizism's Avatar
Re: Re: Re: y pipe problem
please do not suggest to anyone to take their car to pep boys any more..
Old Aug 9, 2002 | 02:40 AM
Dummy's Avatar
it might be hitting against the the piece of metal that is used to secure the stock y pipe...
Old Aug 9, 2002 | 03:08 AM
maxmonkey's Avatar
I have a similiar problem and I suspect that it's the muffler (i have a 2k muffler) hitting the heat sheld. Did the mechanic try to shake the pipes to see if any kind of rattling occured? I had another incident before this with metal hitting metal. It wind up coming from the B pipe section. It had nothing to do with my wsp y or anything. A piece of metal came off the welds that's suppose to hang the pipe onto a rubber piece. It's 6am in the morning so my brain isn't working that well. I hope what I said makes sense.
Old Aug 9, 2002 | 04:40 AM
amax935's Avatar
you are a **** ! this board has gone to hell cause of attitudes such as yours.
Old Aug 9, 2002 | 04:43 AM
amax935's Avatar
Re: y pipe problem
sounds like it could be engine mount related to me.
tnx
Old Aug 9, 2002 | 05:15 AM
male's Avatar
Re: Re: Re: Re: y pipe problem
I'm not saying to have them do anything, I'm saying it is worth a few bucks to have them put it on a lift so you yourself can get a good look. Unless you have a lift in your backyard, it is worth ten bucks to me to have it up on a lift..they may be useless as far as repairs go, but they do have lifts! I bet he has a loose heatshield.
Old Aug 9, 2002 | 07:00 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Re: y pipe problem
had the smae problem...the y-pipe is hitting your front sway bar!! simple solution...go back to the shop and have the guy heat up the section of the y-pipe right over the say bar until its not touching anymore, then its shouldn't make anymore noise!
tnx
Old Aug 9, 2002 | 07:22 AM
blackandwhite's Avatar
To them I'm like an idol
Re: Re: Re: Re: Re: y pipe problem
He has a lift. It's made of plywood, and it used masonry blocks and jackstands...works pretty good too!
Old Aug 9, 2002 | 08:05 AM
Michael's Avatar
Back in a 3rd Gen.
I am going to say it is a heatshield or like DA Max said the sway bar.
I will have a lift one day. When I went and got my parts car in FL the guy I got it from had his own lift in his shop beside his house...I want one so bad.
Old Aug 9, 2002 | 08:42 AM
EdgeProductions's Avatar
I used to have the ypipe hittign my sway bar, then I tightened the clamp that holds the pipe up which commonly gets loose and that helped, but i also had to heat the pipe and make a bend a little so it was raised off the sway when it was installed originally with my greddy sp, and random Tech cat back in early 2001. BTW I will never own anything Greddy every again especially Exhaust, it is so Scheity made. Already rusting and pealing!
Jared
shilov
Feb 19, 2024 09:40 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
Violator
Sep 9, 2015 10:14 AM
Samedi
Sep 3, 2015 01:07 PM
