White smoke?
Old Aug 19, 2002 | 05:06 AM
phantmlord's Avatar
White smoke?
Hi,
I have a 1990 Nissan Maxima and it has been blowing white smoke for about 9 months now. It also turns two of my spark plugs white after about 1 month. I've taken it to two dealers and few mechanics and all no one seems to be able to give me an answer. There is no Coolant mixing the engine. I think it may be a valve problem. Does anybody have any suggestions. Your help is greatly appreciated.
Thanks.
Old Aug 19, 2002 | 08:31 AM
hoodank178's Avatar
Re: White smoke?
Originally posted by phantmlord
Hi,
Thanks.
Sounds like bad valve seals. Cheap parts but labor is going to be expensive.
Old Aug 19, 2002 | 09:53 AM
male's Avatar
are you sure no coolant is leaking in there? Burning oil is not white..got to be coolant. Head gasket? That's my bet.
Old Aug 19, 2002 | 11:15 AM
Taegost's Avatar
That's my $0.017..... Water/antifreeze is the only thing in a car that I can think of that would burn white.
Old Aug 19, 2002 | 03:11 PM
eric93SE's Avatar
This sounds like a bad injector o-ring.
Does it get bad gas mileage? have the injectors ever been serviced or replaced?
I would reccomend that you get the full fuel injection tune up kit, that comes with all the o-rings and gaskets to do the job.
Old Aug 19, 2002 | 07:06 PM
male's Avatar
Please 'splain how a bad injector o-ring makes white smoke. I would think you would end up with leaks at the injector boss and possibly lean conditions..why white smoke?
Old Aug 19, 2002 | 09:11 PM
phantmlord's Avatar
It might not be white smoke, but it does smoke. When I look in the Rear view mirror at night, I see smoke in the headlights that are behind me. It is running lean because white spark plugs are a result of a lean mixture. The injectors have never been serviced after 210,00 miles, so I will give it a try.
Thanks for your help.
REDinLV
Aug 15, 2024 12:30 AM
Fbana41
Aug 29, 2016 12:18 PM
homewrecker
Sep 24, 2015 07:01 PM
ballerchris510
Sep 10, 2015 09:35 PM
