best intake!
Old Dec 15, 2000 | 07:01 PM
flyry110's Avatar
ok so i want a lil more HP, but i don't want to lose too much torque. I like not having to downshift. I've spent alot of my life driving zippy 4 cyl hondas which scream, but are short on torque. what i need to know is where is the best bang for buck, and what is the craziest intake out there. I run iceman intakes for my race CRX, but as far as i know they don't make them for my 92 SE, (the VE engine). anyone out there have any opinions on the best intakes? why do you feel this intake is the best? and what are the pros and cons of it.
Old Dec 15, 2000 | 07:10 PM
Chris Gregg's Avatar
Get Off My Lawn
Mine is the Best!
Pro's: It's cheap, easy to put together, and shortens the distance the air must flow to reach the intake. Con's: Must relocate and rewire the air sensor, and you must cut out the area behind the driver's headlight.
Old Dec 15, 2000 | 07:34 PM
Foo90SE
Today i ran a custom intake of my own...probably similar to Chris's...only i kept the big plastic stock tube connected to the MAF for now(will take it out later). Actually mine is for the VG but i did cut out behind the headlight and ran 3" aluminum ducting from the MAF to the inner fender, mounted my filter on the end, and cut and modified the plastic underbody thing to scoop air up at the filter. Not bad for about 6 bucks worth of supplies and about 2 hrs work
Old Dec 16, 2000 | 09:32 AM
block's Avatar
I bought a used pop charger that wasnt ever actually put on a car. it works great. easy to install and the sound is nice. it gives it a little more jump too.
aw11power
Oct 10, 2021 04:57 AM
JonBlz
Oct 5, 2015 06:02 PM
maxima297
Sep 30, 2015 03:32 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
