Ideas for the unused coin tray..
Old Aug 28, 2002 | 09:57 AM
johnnyo319's Avatar
I been thinkin of something to do with that coin tray next to the Power / Comfort switch for a while now.. I never use it since I don't smoke and use the ash tray for coins.. well here are my ideas so far.
small tweater mounted behind some grille
neon lights
voltage monitor display
I like the voltage monitor display idea.. Any of you have any cool ideas I could consider
Old Aug 28, 2002 | 10:01 AM
Terry28's Avatar
Re: Ideas for the unused coin tray..
neon lights
yeah i was just thinking of that and i think i am going to pit some switches there instead of the coin holder, One for fog light, one for neon in front, one for neon in the back (inside of the car)...
Old Aug 28, 2002 | 11:37 AM
Aaron92SE's Avatar
NWP Engineering.com
Re: Re: Ideas for the unused coin tray..
I love my coin tray. It keeps my coins all organized... nice and neat.
Old Aug 28, 2002 | 11:43 AM
Brendan's Avatar
Re: Re: Re: Ideas for the unused coin tray..
Haha if you got a box and amp in your trunk why not wire some controls to that where your coin tray is. NOS!
Old Aug 28, 2002 | 11:59 AM
male's Avatar
Re: Re: Re: Re: Ideas for the unused coin tray..
Yeah, Nitrous switch, Big Red LED NOS switch
Old Aug 28, 2002 | 12:28 PM
kingrye's Avatar
i tryed hallowing it out cut up a dvd amaray(cover box) and using the plastic as acover to the coin holder and mounted my alaram indicator there and was thinking about swithced, but the aproxie glue didnt stick to the amaray plastic but if i found some black plastic i thinki can get it to work
Old Aug 28, 2002 | 12:42 PM
Scott Fife's Avatar
neon lights
I think you're all missing a fairly obvious use for the coin tray. Take a Dremel grinder and grind out those tabs that separate the coins. How many times have you been driving down the road, enjoying a happy meal and wishing you could dip your french fry in some ketchup. You can't use those paper cups that you pump the ketchup into - they just fall on the carpet at the first turn. The former coin tray will easily hold a standard foil ketchup packet. Enjoy.
Old Aug 28, 2002 | 12:47 PM
James12345's Avatar
LOL
Old Aug 28, 2002 | 01:16 PM
johnnyo319's Avatar
These are all great idea!!
Old Aug 28, 2002 | 03:08 PM
disgookonfiya's Avatar
i used mine to make my switches look clean. I just drilled a hole and put switches in 3 of the spots. One was for my indiglo pedals, one was for my amp so that i don't have to bump when i don't feel like it, and on is just there waiting for something to hook up to it. All the swiches light up and are diff. colors. When anyone asks me what the red one is for, I just tell them to meat me on a straight away and find out......
Old Aug 28, 2002 | 03:11 PM
Jeff92se's Avatar
I'm needing a caw
Ah you found out where my turbo is.
Old Aug 28, 2002 | 09:01 PM
nismo280's Avatar
CLEAN
To keep everything looking clean, you could build a plate that fits inside the tray, then drill holes for switches, so when you dont need the switches you can just push the tray in, and it will look stock. When you need the switches, simply pull the tray out, flip the switch(s) and push it back in...
Tony
Old Aug 29, 2002 | 12:59 AM
kingrye's Avatar
no put a hinge on it so it flips up
Old Aug 29, 2002 | 05:10 AM
nubiannupe's Avatar
OG Maxima.org Member
...James Bond style, huh?
Old Aug 29, 2002 | 07:31 AM
maximum3rdgen's Avatar
make like a mini replica of the din slot door underneath ur radion and put it down there. Just cut a peice of plastic sand it and smooth it paint it black. then use the hinges springs etc frm an ashtray thing.
Old Aug 29, 2002 | 10:20 AM
Brendan's Avatar
If you really got alot of money to work with, put some switches in there for all the stuff we have said, but don't make it a flip face, put a switch on your dash or somewhere so it can be an automatic flip face. Replace it and wire it so it opens on its own, that would be awsome.
Old Aug 29, 2002 | 12:33 PM
Jesse93GXE's Avatar
I removed my coin tray to put switches and a button in.
Blue lighted switch for amp power.
Green lighted switch for car computer power.
Red push-button for early shutdown of the car computer. Normally when I turn off the car, the computer will stay on for 12 minutes (in case I'm just getting case or picking up a friend or running into the store), but if I push the button it'll shutdown right away. In either case, when it shuts down, it tells the OS to turn itself off, then two minutes later it cuts power to the computer.
I never liked the coin tray anyway. The coins always rattled like hell. I keep the coins in the basin under the parking brake. A small cloth over it keeps it hidden, lets me put other stuff on top, and keeps it from rattling.
Old Aug 29, 2002 | 12:47 PM
redzero's Avatar
do you have to do any of these things yourself or can you actually go to a place and have them do it. some of these ideas are bad ***!
Old Aug 29, 2002 | 12:54 PM
Jesse93GXE's Avatar
You pay enough, you can get someone to do anything for you, even wipe your a$$..
I did my switches myself though, pretty easy.
I imagine an audio shop which is used to doing custom construction where aesthetics is important, would do it, though. Probably not worth the cost, though. Unless it's something you're just tacking on to a larger job.
Old Aug 30, 2002 | 07:11 AM
johnnyo319's Avatar
Does anyone have pictures of their switches or coin tray inventions? Post them!!
Old Aug 30, 2002 | 07:56 AM
Maximan190's Avatar
further suggestion: to anyone who has a 5 spd 3rd gen, you can put a single din deck/EQ in there just cut out the coin piece and the blank square to the right of it
Old Aug 30, 2002 | 08:43 AM
Terry28's Avatar
This is my fog light switch by the driver side door.
This are my turbo and nos switch j/k This is all the neon light switch which are inside the car.
Old Aug 30, 2002 | 11:51 AM
Brendan's Avatar
Looks awsome man!
Old Aug 30, 2002 | 03:08 PM
Terry28's Avatar
Looks awsome man!
Thanx....
Old Aug 31, 2002 | 10:56 AM
Aphrodisiac's Avatar
IS THAT WHAT IT IS? A GOD DAMN COIN TRAY?!
Old Sep 2, 2002 | 08:57 PM
i kno how u feel. it took me forever to find out what the hell that was.... but i never used it before, the only thing i ever used it for was to have a spot for my switches to go..
Old Sep 2, 2002 | 09:36 PM
Maximamike's Avatar
Turbo timer or boost controller. I think its a 1/4 DIN slot so anything like that'll fit..
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
Justin Kroll
Oct 1, 2015 07:03 PM
maxima297
Sep 30, 2015 03:32 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
