Hybrid intake is in....
got my '95 Eclipse intake pipe today...the install went pretty well, finally got rid of the the OEM pipe for a nice shiny "no-name" brand intake pipe! the car does feel a little more peppy down mid-range to down low, but I dunno, haven't really tested it yet. and yeah the filter does look kinda high, but it clears the hood just enough and gives the engine bay a different look than from other 3rd gen hybrid intakes.
http://a0.cpimg.com/image/B6/D4/1264...-0200019E-.jpg
http://a2.cpimg.com/image/B8/D4/1264...-020001DF-.jpg
http://a3.cpimg.com/image/B9/D4/1264...-02000146-.jpg
not bad, but can I offer you a bit of advice? Get a better + battery connector. And add another piece os 4 AWG to the ground side of the battery. Your system will thank you for it.
(FYI, you need just as big of ground cable added to the system as + cable. how else would the electricity make a complete circuit, other than through the already maxed-out factory ground).
cool I got you...any particular place the other ground should be grounded, or just on the OEM spot??
Hey Matt could you explain this a little for me, i am having a problem where my headunit turns off at a certain volume and maybe its because of a power shorttage or a battery connection like you said.
Originally posted by Coolice19
DA-MAX could you post a pic of your engine bay with the Hybrid Intake? I still dont understand quite what it is..
basically the hybrid intake is come type of aftermarket intake piping and a cone filter(basically its not just the cone filter and the OEM plastic pipe, but not yet a CAI).
Originally posted by Dummy
I used one from an accord also, i put mine a little over a year ago but never had a chance to post pictures
... Anyways, cheezer used the CAI from a 90-93 accord after i told him it would fit.
Originally posted by Fosgate Fan
uhh...can't see the pics. the links doesn't work.
maxima297
Sep 30, 2015 03:32 PM
yup, it might just be a butt dyno, but I swear my low-end and mid-range improved nicely!!
