homemade sts
Old Sep 17, 2002 | 09:41 AM
skatanic28's Avatar
homemade sts
im gonna try to make the stock shifter have shorter throws like matt suggested awhile back this weekend. just had a couple small questions and concerns. what kinda of grease should i buy for this, silicone or teflon? and i wanna drop it by about 4 inches, and im guessing i cant just move the pivot point that much. so would there be any problems if i just cut or ground the top down and bought one of those clamp-on shift *****? well thanks for any replies
saving 60 bucks and gettin an sts kicks ***
thanks matt
Old Sep 17, 2002 | 05:05 PM
skatanic28's Avatar
im guessing no one else has tried this
Old Sep 21, 2002 | 02:48 PM
skatanic28's Avatar
alrite, well i failed pretty badly with this one
where should i start
couldnt remove the cat cuz the lovely muffler shop just welded right onto the flange instead of removing it first. so i just took off the heat shield and tried to get it from there. with a huge socket extension, i could get to 2 of the 4 bolts. so i emptied a can of liquid wrench up there and let it soak in for awhile. in the meantime, worked inside and got the shift **** off. at least that went easy. so then i got back under there and tried to free up some of those bolts. they were in pretty rough shape so i took it eaasy on them. well i guess not easy enough cuz the first one snapped off like nothin. so ****, one bolt down, 3 left on. they all looked the same and i didnt want to risk break anymore of em, so i just stoppped right there.
so im thinkin im just gonna take a hacksaw and cut down about 3 inches, it will make the throws a little bit shorter too i guess. i oculd always just kill the rest of the bolts and then retap em.
at least i didnt spend 60 bucks on the pacesetter just to find this out.
Old Sep 21, 2002 | 09:58 PM
Lordrandall's Avatar
You can get the shifter out without removing the CAT. I've done it 3 times at least.
Good luck moving that teflon shift ball however. I was not able to do it.
Oh, just remove some of the exhaust hangers to get the cat, etc. out of the way so you can remove the shifter.
Old Sep 22, 2002 | 03:25 PM
skatanic28's Avatar
i know you can do it without takin the cat off, it just seemed a lot easier that way
the reason i couldnt do it though was cuz all the bolts were rusted and frozen. the heads were falling apart and i didnt feel like breakin em all then retapping everything. im just gonna cut it now i think.
i was looking around for a **** that can fit over the actual lever instead of on the threaded part. up here at school i didnt find anything, but im goin home next weekend and im sure theres a much bigger selection in buffalo. so hopefully ill get it done then.
Old Sep 23, 2002 | 09:02 AM
male's Avatar
Just hack saw a few inches off the top. Sounds ghetto, but everyone who drives it comments on the nice short throw. I took off about 4 inches, then slipped on a nice ****. Works for me and looks a ton better than that big dorky stock one.
Old Sep 23, 2002 | 10:02 AM
skatanic28's Avatar
sounds good to me
you took a whole 4 off?
any problems with the ergonomics of it?
Old Sep 23, 2002 | 10:17 AM
male's Avatar
Originally posted by skatanic28
sounds good to me
Actually that was sort of a guess..it's been a ahile since I did it. I do remember taking off a few inches, then gooing a little more because it was still a tad too tall. Maybe it was more like three inches. I do suggest NOT using a hack saw..took a LONG time and two blades to get through it. Use a reciprocating saw (sawzall)..much faster. I love the shorter thrw, was easy to do, looks cool, and it cost me only the two blades and the ****.
Wolvee
Aug 11, 2015 12:24 PM
1992maximase30
Aug 5, 2015 09:27 PM
Victim64
Dec 7, 2001 10:49 AM
Infinissan
Aug 2, 2001 09:26 PM
James92SE
Oct 30, 2000 01:51 PM
