Would this be best for making cold air intake?
Old Sep 20, 2002 | 08:51 AM
doomtoo's Avatar
What I've gotten from searching around on the board- besides trying to figure out what OSCAI is- that the best way to combine normal after market intake and CAI is to take of the black plastic on the end of the intake, and attach some sort of hose(from PVC to Dryer tubing) and run it down by the front bumper. IS this correct, and would it be best to do?
I just bought the intake(pop?), so I want to still use it, combined some how with getting cold air.
My friends protege', was allready all fixed up when he bought it, but his cold air intake is the tubing comming from that timing peice, running down to the front bumper, where it connects into a after market air filter.
Would that be better to try and do?
Old Sep 20, 2002 | 09:04 AM
Jon91SE's Avatar
Pusssseeeehhhh
Best thing to do is buy a CAI.
WSP has the cheapest CAI around...
Old Sep 20, 2002 | 09:16 AM
doomtoo's Avatar
ABout how much would you say WSP costs? Would I have to get rid of my curent intake, or is the WSP the hoses to attach it onto?
Old Sep 20, 2002 | 09:49 AM
doomtoo's Avatar
If I could, I'd rather make my own, 1. Becuase I'll know what is going into it and how to do it(instead of possible POS), and 2. Money :S Can barely do cheap or none. Would rather do cheap, if it helps about as much as something 5x the price.
Old Sep 20, 2002 | 10:44 AM
skatanic28's Avatar
if thats all ya got is the filter, you have a few options
if ya wanna go the same route as all the other cai, you can drill into your fender and run pvc down into that an put the filter on the end. your gonna keep the stock midpipe then? it might be tricky to mount the pvc onto the end of the mas, but im sure you could with a flange and an adapter. or you can just use dryer hose to bring cold air to where the filter is now,
Old Sep 20, 2002 | 10:45 AM
pearl93max's Avatar
200-250 w/ a filter
Old Sep 20, 2002 | 10:52 AM
blackandwhite's Avatar
To them I'm like an idol
Really?
Originally posted by pearl93max
200-250 w/ a filter
Blake? Do you know something I don't? Their website says $155. And they haven't had any in stock for 4 months (that I know of, I've been calling every week).
They told me that pricing would be different, but if I knew they were going to be 200-250 then I would have went to Place Racing or Cattman before I waited 4 months on them.
Old Sep 20, 2002 | 10:54 AM
doomtoo's Avatar
I think the dryer hose might work best for me... 1. I don't want to have a hole in the bumper becuase 2. I want to save up and get at least a 92' SE 5spd Maxima, becuase it has, from what I've heard(correct me, and say why, if I'm wrong), it has a much more powerful engine, and if I put all the money into this one for performance, it wouldn't be nearly close to the performance of putting that much money into the SE. So save and wait, I shall.... and do little things untill then!
Old Sep 20, 2002 | 10:59 AM
Siege's Avatar
Suggestion:
Go to a truck shop or maybe muffler shop and purachase about 2.5 ft. of 3" exhuast flex pipe. You can get the stainless steal pipe for a few dollars more, but the galvanized is cheaper and paintable. Should run under $20 including tax, any more and they're ripping you off. Go to Home depot, buy one PVC rubber connection boot. You will have to cut and rewire your MAF. Cut hole, run pipe with the MAF relocated into the fender. The VE will need more pipe than 2.5 feet. Over a year and no problems. Email me for more specifics if this is where you want to go.
Old Sep 20, 2002 | 04:36 PM
lophix's Avatar
200-250 w/ a filter
hey is yurs a cai or a pop in the pic?
Old Sep 21, 2002 | 04:16 PM
PATRICK94SE's Avatar
Re: Suggestion:
WHY?
Old Sep 21, 2002 | 06:09 PM
Sudesh's Avatar
Re: Re: Suggestion:
Personally, I really don't see the point to anyone posting about Intakes of any sort anymore. The fact is that you have CAI's made for you already. A couple of guys have devised their own cai's, if you search you'll find all the info about intakes as you can possibly want.
If you feel like going a cheaper route, take a picture of one of the existing cai's to a muffler shop that does mandrel bends. Tell them that you would like them to bend you that exact thing. They will use steel instead of aluminum, yes it's heavier, but it keeps heat out better. This is good alternative route for getting a proper cold air intake and not one of those 'ghetto' rigged things.
Old Sep 21, 2002 | 06:29 PM
Siege's Avatar
Re: Re: Suggestion:
Originally posted by PATRICK94SE
WHY?
It allows for a shorter distance from the intake of the VG to the fender. By cutting down the surface area of the tubing (because it's shorter) which is heated by the high temperatures from the engine, you get higher velocity, less turbulant, and possibly cooler air. I say possibly because the degree to which the temperature of the tubing actually heats up the air moving inside it is not significant in terms of hp or performance when comparing one length (my way, per say) to the longer (rapping it around the battery and then into the fender). But, I'm no expert, just my reasoning and I may be wrong.
Old Sep 21, 2002 | 06:51 PM
Matt93SE's Avatar
STFU n00b!
Just leave the damn thing alone if you don't plan on keeping it. the money you save from not doing anything do it will will be just another step towards your next car.
A32goldylocks
Sep 2, 2015 06:39 AM
95Maxi
Aug 29, 2015 09:38 PM
bc992164
Aug 26, 2015 12:19 PM
cheftoo
Aug 20, 2015 05:17 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
