How can I remove rear deck 3rd brake light?
Old Sep 26, 2002 | 04:45 PM
doomtoo's Avatar
I've got thus far on getting to the rear speakers, but I can't get that rear blake light off. thewre are two screw things on the side, which undone, don't seem to do much, but on the top of the inside of the trunk, it looks like they are screwed down from the inside! I can't figure out how to get them off... I tried pulling, but I didn't want to break it
(91 nissan maxima GXE)
Old Sep 26, 2002 | 07:55 PM
Shugarhi's Avatar
Re: How can I remove rear deck 3rd brake light?
heh... i was dynamatting my rear deck just the other day and i couldnt get that damn brake light off either, plus i didnt wanna mess with it since there are wires goin to it... so instead i just lifted the rear deck carpet and started from there
Old Sep 26, 2002 | 07:57 PM
Shugarhi's Avatar
sorry i kinda went off-tangent.. in answer to your question - IDK
Old Sep 26, 2002 | 08:01 PM
«§»Craig B«§»'s Avatar
push in on the center of the clip then the whole clip should be able to pull out
repeat on other side
Old Sep 26, 2002 | 08:17 PM
matt92gxe's Avatar
exactly what craig said. i had to remove mine a few weeks ago because one of the bulbs went out and i had to replace it. it is kind of a pain to remove, but just follow craig's instructions and BE PATIENT with it!! once both clips are out, it will just slide out and you can disconnect the wires and remove it completley, so it will be out of your way.
Old Sep 26, 2002 | 09:00 PM
doomtoo's Avatar
So you mean on the sides of the ligt how there are those phillip head plastic clips, or the ones underneath in the trunk where there are plastic clips that are screwed in from the top? I'm gonna go try and see if the plastic ones on the sides will come out then...
thanks, and I just want to be sure on which clip
Old Sep 27, 2002 | 01:26 PM
Matt93SE's Avatar
STFU n00b!
give the phillips heads about 1/8 or 1/4 turn and you'll feel them release their grip. then simply pull the entire fastener out.
The light will then come loose from the bracket, and you unhook the wires. then use an (8mm??) socket to remove the two bolts on the rear deck and the bracket will come off and you're done.
jskirwin
Jun 8, 2016 08:49 AM
JMag90
Aug 25, 2015 09:17 AM
Samedi
Aug 13, 2015 04:05 PM
Mcnabb34
Aug 11, 2015 08:45 PM
