Interesting note: rear sway bar
Old Dec 20, 2000 | 08:46 PM
RosenKen's Avatar
If anybody didn't know, the SE's is a bit bigger than the GXE. 13.8mm GXE vs 15.0 mm SE. However, front bars are the same. This is out of my '93 service manual, but I'm willing to bet its the same for all 3rd gen years.
I'll have a stock SE rear sway bar laying around when I get my SusTec's in (should be here any day now). any GXE's want to buy it for cheap??
Old Dec 20, 2000 | 08:48 PM
Maximamike's Avatar
The Nissan also states that the cams in the 300zx are the same for all 90-93 300zxs. But the auto TT and the manual TT cams are both different. They also don't note the change in cams from 93 on. Don't always trust the manual
Old Dec 20, 2000 | 08:49 PM
Nismax
how cheap is cheap... you think it will fit 3rd gen?
email me asap!
Old Dec 20, 2000 | 08:50 PM
Maximamike's Avatar
Since its off his 93 SE I'm just guessing it will fit in a 3rd gen...
Old Dec 20, 2000 | 08:53 PM
Sith's Avatar
haha
Old Dec 21, 2000 | 11:33 AM
brubenstein's Avatar
Since you've got a FSM, you you please check the specs on the front and rear springs (inch/lbs. and length) for SE vs. GXE. Now I know to keep an eye out for a SE rear sway bar.
Old Dec 21, 2000 | 01:49 PM
RosenKen's Avatar
No prob...
GXE SE
auto manual auto
free mm (in)
length RH side 408(16.06) 379 (14.92) RH side 379(14.92)
LH side 418(16.46) LH side 387(15.24
that's all I have on the springs. No in/lb. I also have wire diameter and coil diameter specs, and also the ID color tags.
PS got my Suspension Techniques sway bars today, they should be on tomorrow afternoon
Old Dec 21, 2000 | 02:04 PM
RosenKen's Avatar
hey, that didn't come out too well. oops. those #'s are for front springs by the way
Old Dec 21, 2000 | 05:27 PM
OK, the GXE springs are longer, so I assume softer (would need the wire dia.). The engines are different, and have different weights. What about the rear springs?
If you still have the old rear bar, and are in NYC (I'm in Brooklyn), I'd be interested in buying it.
AcuraLegend
Sep 22, 2015 04:22 PM
ef9
Aug 27, 2015 07:21 AM
seesole
Aug 26, 2015 11:22 AM
Maxboy23
Aug 20, 2015 09:33 AM
MaxStock
Aug 14, 2015 10:03 PM
